headlight woes
headlight woes
Went to leave for work. Passenger headlight flicked on then off. Tried lights off and on, same issue.
Any idea where to start looking? Sound like ballast or bulb? Too cold to take apart right now, going to check ground and connections quickly in the am.
Morimoto bulbs and ballast barely over a year old
I would try starting with bulbs. Take the "Good" bulb and switch it to the other side, if the same problem persists it's the ballast. If it lights up, it's the bulb.
