headlights dim with cap. NEED HELP
Caps are just a waste of money. They don't work, also you don't need to replace your battery or alternator. Its all about the big 3. Here is a link to what I'm talking about.
http://www.caraudio.com/forum/showthread.php?t=152355
Hope this helps out. Which it should.
DON'T WASTE MONEY ON STUFF YOU DON'T NEED
i partially agree the big 3 is normally what i would recommend but with the battery in the back the wire is pretty beefy compared to other cars ive seen. Stock wire is ~ 4g so doing it would require at least 1/0 and even then ur getting roughly a 3rd of the resistance so its not going to be a giant effect. Swappin the battery is probably one of the best things to do in balts... Im not sure if companies make HO alts yet either because they didnt before i started the dual alt on my car
Sick bro im going to upgrade my system i hav alpine 4 channel f340 for the 6.5 and 6.9 and a eclipse xa2000 and a 10in eclipse sub and my light dim when volume at like 80%....(upgrade)im gonna get a L7 12 and a 1000watt alpine for the sub will a yellow top optima and the big 3 help for the new set up plus the alpine f30 wat do you think?? will my light still dim wit yellow top and big 3
#38
Caps are really good, as distribution blocks. Get a audio specific battery like Kinetic, XSPower, or Shuriken or a new alternator. You can get secondary batteries or replacement primary batteries.
