headlights dim with cap. NEED HELP
Old 03-13-2008, 10:23 PM
EmperorJJ1's Avatar
??? wouldnt know. but you should get one with ur system
Old 03-13-2008, 10:34 PM
doubledirtyc's Avatar
i've been looking but i cant really cant find a reputable dealer what type of amperage should i be looking for do you think emp
Old 03-14-2008, 12:29 AM
EmperorJJ1's Avatar
a good 200a would be helpful. Nothing over 250 because the current at idle becomes useless. even 200a isnt the best idle power
Old 03-14-2008, 01:35 AM
mikey13's Avatar
Caps are just a waste of money. They don't work, also you don't need to replace your battery or alternator. Its all about the big 3. Here is a link to what I'm talking about.
http://www.caraudio.com/forum/showthread.php?t=152355
Hope this helps out. Which it should.
DON'T WASTE MONEY ON STUFF YOU DON'T NEED
Old 03-14-2008, 02:00 AM
EmperorJJ1's Avatar
i partially agree the big 3 is normally what i would recommend but with the battery in the back the wire is pretty beefy compared to other cars ive seen. Stock wire is ~ 4g so doing it would require at least 1/0 and even then ur getting roughly a 3rd of the resistance so its not going to be a giant effect. Swappin the battery is probably one of the best things to do in balts... Im not sure if companies make HO alts yet either because they didnt before i started the dual alt on my car
Old 01-03-2013, 02:54 AM
bluebolt713's Avatar
Originally Posted by doubledirtyc
is there a good place to get a high output alt because i have 2 yellow tops and 2 caps and my lights dim lol
Wat are u running 4 15???jk try dcpower or machman alt they make som bad **s high output alt ...and by the way wat are u running wit 2 yellow tops??
Old 01-03-2013, 03:00 AM
EmperorJJ1's Avatar
https://www.cobaltss.net/gallery/fil.../photo0091.jpg
Old 01-03-2013, 03:52 AM
Sick bro im going to upgrade my system i hav alpine 4 channel f340 for the 6.5 and 6.9 and a eclipse xa2000 and a 10in eclipse sub and my light dim when volume at like 80%....(upgrade)im gonna get a L7 12 and a 1000watt alpine for the sub will a yellow top optima and the big 3 help for the new set up plus the alpine f30 wat do you think?? will my light still dim wit yellow top and big 3
Old 01-04-2013, 01:10 AM
EmperorJJ1's Avatar
shouldnt but wire size makes a difference as well
Old 01-04-2013, 01:15 AM
Boostin15's Avatar
This
Old 01-04-2013, 02:18 AM
  #36
thanks man i
Old 01-04-2013, 11:22 PM
  #37
NOLAGSS's Avatar
mine used to do this also i figured out finally it only dimmed them when the amp was bridged
Old 01-07-2013, 12:35 AM
  #38
VancouverTurbo's Avatar
Caps are really good, as distribution blocks. Get a audio specific battery like Kinetic, XSPower, or Shuriken or a new alternator. You can get secondary batteries or replacement primary batteries.
Old 01-07-2013, 12:57 AM
  #39
EmperorJJ1's Avatar
actually in most cases the caps with the multiple inputs and outputs use really cheap metal that doesnt conduct nearly as well as a normal d block
Old 01-07-2013, 01:19 AM
  #40
redcobalt07's Avatar
bigger cap
Old 01-07-2013, 12:18 PM
  #41
tru2nrtt777's Avatar
bigger cap
More strain on battery.
Pasierbek
12-10-2015 07:22 PM
allpro666
10-06-2015 08:11 PM
09-26-2015 06:44 PM
brickloaf
09-21-2015 02:17 PM
jonnycat
09-19-2015 12:58 PM
Quick Reply: headlights dim with cap. NEED HELP
