Headlights only sometimes come on at night
Hey i have retrofit HIDs and they work great normally, but recently some nights they just won't turn on at all. Sometimes after a few minutes of driving they just randomly come on.
Turning them on automatically doesn't work, nor does using the highbeam switch.
Just wondering if anyone has ever had an issue with this, not sure if it is a problem with my daytime/nighttime sensor, some of the connections or fuses, or what.
Recent work since the issue came up was a GM deck harness replacement (not sure if relevant in anyway).
Thank you for any input.
I'll check all the plugs that would have an impact on both of them, because either they both are off, or both are on, and always turn off/on at the exact same time.
Could also be my light sensor maybe, anyone have an issue with that before?
Went in, checked all the connections multiple times, cleaned all the ones that looked iffy, still no luck.
My CCFLs both always light up, and my turn signals also.
I don't understand why it takes them a few minutes sometimes to turn on if they ever do.
Nothing is fully broken since they will usually will eventually both turn on at the same time, I'm really confused and I haven't read anything like this before.
Id say fiddle with teh connections when you start the lights on..cuz I had to fiddle with em to get the drivers side to come on until I replaced he connectors
I tried doing that exact thing briefly when i had all taken apart with no luck.
Starting to think my relay itself may be crapping out a bit.
They were made by mkulrey13 / buyhids / hidwerks... PMed him, he is usually good about customer service stuff so hopefully he can help me out with parts if I need them. Having no headlights make night driving / leaving town pretty much impossible so this needs to get fixed ASAP.
Ya but both ballast wouldn't go out then back on at the same time.
Think the only option here that makes sense is the relay i think.
Hopefully a response tomorrow, see what he says
