Help?? Aftermarket hu install??
Help please i have a 2005 cobalt ss superchargerd.tvs with the pioneer system i want to put a double din in later on down the line but for now i want to instal l a simple jvc cd player i want to now how to keep my stock pioneer sub in the trunk and al that hooked up and playing with the jvc cd player! Wich harness will i need?? And if you have any insturctions on how to make the stock sub work and wiring info please help thanks...
With my 06 I just spliced in the harness for the cd player and the stock sub workd fine. I lost the use of the buttons on the steering wheel. I dont care tho. Cruise control still works tho
THANKS.. I REALY DONT CARE FOR STEERING WHEEL CONTROL RIGHT NOW IL BUY A ADAPTER FOR THAT LATER... BUT WHAT DO U MEAN JUST SPLICED IN THE HARNESS FOR THD CD PLAYER? U HOOKED THE WIRES FROM YOUR CD PLAYER DIRECTCLY UP TO YOU CARS? FACTORY HARNESS THAT USE TO PLUGED INTO THE FACTORY RAdio? and it workd? or u had to by a seperate harness to plug in to the cars original harnes? and then wire it up to the cd player?
just want to know how to make my stock pioneer sub along with the rest of the pioneer factory speakers n all that work with the jvc cd player.. n wich harness will i need to do that if it can work.. i tryed to hookd the player up direct by splicing into the car factory harness and it only got power no sound,, its a good thing i didnt cut the wires a guy at a electronics place told me. he said i needed a special harness he sold me one and it it didnt fit, and thats all they had.. so i wana know which is the correct harness i need and i also would liek my stock sub to work with the cd player thanks.... im way in the bahamas....
https://www.cobaltss.net/forums/elec...aq-read-96094/
5.) What Harness do i need for my 05-06?
Metra = 70-2103
the stock amp powers all 7 speakers and only requires the 4 front rear right and left inputs
Metra = 70-2103
1 Post
It's not hard at all. Buy that ^ harness. Color match everything, and you might have a run a wire to the fuse box (I did aleast) of power. I was done in an hour. And I've never messed with this type stuff before.
thanks!!!! alot will buy that harness!.. anything else i shud be informed of about the install.. n do i need the atena adaptder? if i dont have it whats does that mean ? that i just wont pick up am/fm ? cuz for right now that dosent matter just want some musicasap, cds,etc
Delta coupe
09-30-2015 08:11 AM
