Help With Aftermarket Speakers
I want to get some aftermarket speakers that sound better than the stock speakers but i dont want to deal with taking out the stock amp and sub. can someone help me to figure out what kind of speakers would work good with the stock amp.
What kind of amp would be best to buy? will it still support the stock sub? i want it to still support the stock sub and the speakers
your best bet would be a 5 channel amp
http://www.cardomain.com/item/ROCPOWER1000 This rockford amp may be too powerful for the sub but compaired to the alpine i would get it...
http://www.alpine-usa.com/US-en/prod...model=MRA-F350
whats a good aftermarket amp that i can use to replace the stock amp. i want more watts for the stock sub and speakers but i dont want it to be more than $300
imo 300 wont do it for a singe amp direct replacement... reason being is for a single amp you will need a 5 channel and since they are rare they get pricy. now you might be able to get a dual amp setup but depends on what you consider "good" for a dual amp setup (your best bet) look for a 4 channel that is 2 ohm stable and and a 2 channel amp that puts out 200w or so bridged at 4 ohm
i dont know if any1 knows the rating of the stock sub. in my opinion the stock sub is a waste of time, save up get some new ones. i got the jl audio w0's. best bump for ya buck, get 2 twelves they are about 100 each and a decent amp u probably end up spendign around 500 but u wont regret it
brickloaf
09-25-2015 09:10 PM
