help with ign wire
help with ign wire
installing a Ailpine CDE-9852, i got a American international wire harness GWH-404, but i have to run my own ign wire where can i hook that into i have a 05 ss/sc
wiper fuse, located on the pasenger side fuse box, perfect spot for a deck...or u can use the sunroof fuse, or the IGN fuse under then engine bay...but the wiper one is a lot closer...and i recommend getting a "add a cicuit" for that wire....u can find them at autozone for pretty cheap
looks like that
looks like that
looks like that
looks like that
the deck itself has a 10a fuse so... if ur pioneer and using the stock amp ull be fine. you wont ever get the amp in the alpine to draw the full 10a. if not i would possibly bump it up to a 15a. ud have to put it in the sunroof slot thou and hope you dont have a sunroof
