Help Installing HID in Gen 1 Projectors
I bought an HID kit from buyhids.com, with the relay and anti-flicker harness, great price fast shipping. It said the kit was plug and play, but from what I can tell it is not. I have Gen 1 projectors the bulb fits the head light, but none of the plugs on the kit match up to the car. The bulb is to the ballast connections I got, ist all the other plugs and wires that I have some confusion about. Also where do I put the relay harness?
The harness with the cap plugs into the ballast. the PINs on the bulb are not used. The PINs on the harness plug into the drivers side H1 connectors. Vice versa for the passanger side and the pins are not used at all on that side as everythings controled by the drivers side. Plugs on the harness plug into the anti flicker caps which are plugged into the ballast. As PnP as you can get man.
I got it. Thanks for the help. the 3 sets of h1 connectors had me confused. Once you said everything runs off of the drivers side it all made sense to me. Thanks again for the help, and now I can't wait for it to get dark so I can see my hard work pay off.
Delta coupe
09-30-2015 08:11 AM
