Help with new Sub
Old 08-25-2006, 09:45 AM
  #51
Xavipheus's Avatar
Im aware, but i cant find the fuse taps anywhere so hes getting them for me and an inline fuse to go with the wire
Old 08-25-2006, 09:46 AM
  #52
StinkBOMB's Avatar
Originally Posted by Bandit2941
Wow. Sorry bro but that's totally wrong. In your words; you're seriously going to tell someone he's going to "burn the voice coils out" if he doesn't give a sub enough power???? No offense intended, but you should know what you're talking about before you reply with something like this.......
Yeah, and so should you. What happens when you overdrive a voice coil and don't give it enouph power?
Old 08-25-2006, 10:11 AM
  #53
Bandit2941's Avatar
Not giving the voice coil enough power does NOT overdrive it!
I think you're trying to allude to clipping, in which the output of the amplifier gets 'clipped' and starts to resemble a square wave. This happens when the loudness of the system isn't enough for the user and the user cranks the volume/gain knobs. Instead of nice sine waves, the sub gets waves that resemble square waves with much higher output. The speaker cone doesn't move properly (ie with a pure square wave its either on or off), and the lack of regular movement doesn't cool the voice coil which could lead to damage. However, with a sub like that it would probably take an awful lot of clipping and the sub would sound really bad to the listener before it hurt it.
Old 08-25-2006, 01:00 PM
  #54
StinkBOMB's Avatar
Your long paragraph is what I was refering to. And while you are right, I wasn't refering to the lack of power overdriving it, I was refering to the end user overdriving it. You can run as much power as you feel like, just make sure it's clean power. I've heard some pretty bad systems that people thought were the heat, until they blew their subs. Come on, would you honestly recommend running a sub like a Type R on that amp? I ran mine on a 1501D, and they beat. I didn't give the guy any bad advice or bum scoop, you need to feed those subs.
Old 08-25-2006, 02:02 PM
  #55
Bandit2941's Avatar
I just hate it when everyone blindly says "underpowering a sub blows it" because that is totally not true. You can run as little or as much (provided you don't grossly exceed recommended max's) power through a sub as you want, provided you don't drive the amp into clipping. Obviously you know what's going on but someone that doesn't will read that and then start saying the same without knowing that it's really clipping that hurts a sub.
I wouldn't necessarily recommend that sub for that amp, but I don't think it would sound horrible, that amp produces 360 watts RMS which is well within the recommended range of 200-500 watts RMS of the sub provided the sub is wired for a 2 ohm load.
Old 08-25-2006, 05:23 PM
  #56
Xavipheus's Avatar
Yeahhhhhhhh so the sub is coming on the 30th
Expect to see some pictures late next week...
Old 08-27-2006, 12:06 AM
  #57
Xavipheus's Avatar
Alright everythings all wired up, instead of using the sunroof fuse i used the one above it which was empty. We used a test light and figured out that its only on with the key, so we hooked up the remote power wire into a fuse and then into the fuse box, now the amp goes on and off with the key on ACC =)...So basicly everything is all wired and ready to go, just waiting on the sub now =)
Old 08-27-2006, 03:32 AM
  #58
xspyder85x's Avatar
nice job, wasnt as hard as you thought it was, right?
Old 08-28-2006, 03:37 PM
  #59
Xavipheus's Avatar
Not when your girlfriends stepdad is a mechanic =P
Old 08-28-2006, 04:58 PM
  #60
xspyder85x's Avatar
true.
Old 08-30-2006, 06:19 PM
  #61
Xavipheus's Avatar
Ahhh man its all installed and damm does this baby punch, the whole car rumbles, its amazing, theres a slight rattle in the trunk somewhere, but nothing I cant drown out =)
Ill take some pics soon and post, thanks guys for all the help!
Old 08-30-2006, 06:23 PM
  #62
xspyder85x's Avatar
lets see them
Old 09-03-2006, 01:39 PM
  #63
Xavipheus's Avatar
Alright here are the pictures of the sub install, including the fuse panel and my neons, check it out...
My car is a little dirty hahah, ive been to lazy to vacume it, all this rain has brought crap into my car
Old 09-03-2006, 03:25 PM
  #64
xspyder85x's Avatar
wow those pics are freaking huge, you should downsize them. but it looks pretty good, im not too crazy on the neon placement, but its your car (it took me forever just to figure out where they were, it was a disorienting picture). do you have an inline fuse on that wire on the fusebox?
Old 09-03-2006, 04:23 PM
  #65
Xavipheus's Avatar
Yeah its that big black thing, look at the blue wire, it goes into the black fuse and then into the fuse panel
Old 09-03-2006, 04:40 PM
  #66
xspyder85x's Avatar
ok good, i thought that was it. its funny though, you didnt even do what we had talked about, the whole slpicing the fuse, but i guess that works
Old 09-03-2006, 05:35 PM
  #67
Xavipheus's Avatar
I know, I couldnt find Fuse taps at any store around here so i went with this method
