help speakers makin weird noises
I recently installed a double din indash cd dvd didnt buy the expensive harness to keep door chimes but i got the cheap metra one works but speakers have a high pitch ringin comin outta them I thought maybe interference or bad connections so took it back apart an rewired everything but its still there whats makin this noise.
id like to know to. i also put in a double din pioneer cd dvd player with ALL the fancy harness's for the chimes and onstar and crap and my back passenger speaker is making like a humming noise.
if the ground from the harness is solid then id try adding an additional ground and see if that helps if nto then try running only that second ground and see if that does it
your probably getting ground loop which is alot harder to do and alot harder to fix when your not using rca's
Alright thanks i think i might just put the stocker in till i get a better hu this one slides down an sticks out i want one that fits flush
DANRICKARD
10-01-2015 12:08 AM
