Help Sub into Trunk (56K beware!!)
Old 12-19-2006, 08:57 PM
  #51
HackAbuse's Avatar
You need a line level converter
Old 12-19-2006, 11:23 PM
  #52
diablo2007's Avatar
you can also just take a rca cable and cut off one end,to do this wire the end you just cut to the speaker of your choice, and plug the other end in to the amp
Old 12-20-2006, 03:38 AM
  #53
EmperorJJ1's Avatar
im pretty sure that amp has high level inputs anyway since pretty much all of them ive seen have them
Old 12-20-2006, 03:43 AM
  #54
Red06LS's Avatar
Go RF!! Thats all i had to say.
Old 12-20-2006, 07:11 AM
  #55
HackAbuse's Avatar
Remove the back seats, they are held on by four bolts, thats what i have to do to fit my custom made boxes in
Old 12-20-2006, 07:23 AM
  #56
Boosted_SS's Avatar
Originally Posted by Tung
well i decided to get a new amp from future shop since it was on sale. I got a Rockford Punch 1 amp (P3001) 1 channel. And i asked one of their techs how much it would be to install the sub and amp but they said i would need a new headunit because it dosent have RCA outs.
I searched the forums but wasnt quite sure what some of the guys meant. Is it possible to get RCA cable and cut off one end and T splice it with one of the rear speakers and plugging the other end into the amp and using that to get a signal for the sub????
Any ideas would be greatly appreciated.
get an output converter
http://www.crutchfield.com/S-l4XUDGf...rter&i=142SLC4
Old 12-20-2006, 08:06 AM
  #57
Bandit2941's Avatar
Only if the amps RCA jacks are high (speaker) level inputs - which is doubtful.
Old 12-20-2006, 08:15 PM
  #58
mugencivicsi's Avatar
Remove the back seats, the the back parts, not the actual seat (under you A$$) part.
you will gain a bit more space with it
try placing the sub somewhat face down, put the pointed end in first, and slowly tilt the box back wards... once you get the box in there you should have plenty of room to move it around..
crappy drawing but with some slight manouvering it should go it
  #59
if anything take out the sub and put it back in to avoid damaging it...
Old 12-20-2006, 09:53 PM
  #60
Boosted_SS's Avatar
if you all would read the whole post you would realize that he go it in already
Old 12-20-2006, 09:57 PM
  #61
kingg5's Avatar
anyone have/had experiences with a pyramid amp(PB448)???
it came with my buddy's sub and when i talked to the guy at a&b sound they laughed at me......idiots
look at the name...this is waht i was taught....pureAmid. that amp would probealy be good for ur mids..but for a sub...poooooooooooooooo
Old 12-20-2006, 11:05 PM
  #62
Bandit2941's Avatar
If I had two amps, one of which I thought sounded better than the other, I would definitely want the cheaper amp driving the sub(s) instead of midrange!!
Old 12-21-2006, 07:20 AM
  #63
Boosted_SS's Avatar
I agree
Old 12-21-2006, 02:25 PM
  #64
EmperorJJ1's Avatar
lol if i had to had to then id do that but best choice would be to sell the crap amp and buy a better one
Old 12-24-2006, 07:59 PM
  #65
Tung's Avatar
alright guys my very last n00b question before i start thumping the sub, how do you wire the line out converter to the stock headunit??
Thanks guys and merry christmas!
Old 12-25-2006, 01:46 AM
  #66
Boosted_SS's Avatar
wow dude i would just wire them into the rear speakers
Solid green goes to the positive on the drivers side speaker (brown wire)
Green and Black goes to the negative on the drivers side speaker (yellow wire)
Solid gray goes to the positive on the passenger side speaker (dark blue wire)
Gray and Black goes tot he negative on the passenger side speaker (light blue wire)
then twist the who black wires together and put then on a good chases ground
Hugger1975
10-15-2015 03:28 PM
camaromanss1992
10-01-2015 10:51 PM
grampss
09-27-2015 08:51 PM
c_m_shooter
09-27-2015 04:40 PM
CobaltSS 16
09-06-2015 02:04 PM
Quick Reply: Help Sub into Trunk (56K beware!!)
