Help Sub into Trunk (56K beware!!)
#56
Originally Posted by Tung
well i decided to get a new amp from future shop since it was on sale. I got a Rockford Punch 1 amp (P3001) 1 channel. And i asked one of their techs how much it would be to install the sub and amp but they said i would need a new headunit because it dosent have RCA outs.
I searched the forums but wasnt quite sure what some of the guys meant. Is it possible to get RCA cable and cut off one end and T splice it with one of the rear speakers and plugging the other end into the amp and using that to get a signal for the sub????
Any ideas would be greatly appreciated.
http://www.crutchfield.com/S-l4XUDGf...rter&i=142SLC4
#57
Originally Posted by diablo2007
you can also just take a rca cable and cut off one end,to do this wire the end you just cut to the speaker of your choice, and plug the other end in to the amp
#58
Remove the back seats, the the back parts, not the actual seat (under you A$$) part.
you will gain a bit more space with it
try placing the sub somewhat face down, put the pointed end in first, and slowly tilt the box back wards... once you get the box in there you should have plenty of room to move it around..
crappy drawing but with some slight manouvering it should go it
#61
anyone have/had experiences with a pyramid amp(PB448)???
it came with my buddy's sub and when i talked to the guy at a&b sound they laughed at me......idiots
#62
Originally Posted by kingg5
look at the name...this is waht i was taught....pureAmid. that amp would probealy be good for ur mids..but for a sub...poooooooooooooooo
#63
Originally Posted by Bandit2941
If I had two amps, one of which I thought sounded better than the other, I would definitely want the cheaper amp driving the sub(s) instead of midrange!!
I agree
#65
alright guys my very last n00b question before i start thumping the sub, how do you wire the line out converter to the stock headunit??
Thanks guys and merry christmas!
#66
wow dude i would just wire them into the rear speakers
Solid green goes to the positive on the drivers side speaker (brown wire)
Green and Black goes to the negative on the drivers side speaker (yellow wire)
Solid gray goes to the positive on the passenger side speaker (dark blue wire)
Gray and Black goes tot he negative on the passenger side speaker (light blue wire)
then twist the who black wires together and put then on a good chases ground
camaromanss1992
10-01-2015 10:51 PM
