hid lights---help
hid lights---help
help please
i just installed hid bulbs in my stock headlights but lights wont come on when i start the engine not even when i set the alarm on
i have to turn them on manually
any ideas why??
any ideas why??
do they turn on when you turn the lights on manually?
are you sure you plugged everything in correctly? the ballast bos and all 6 or so wires that go with it, did you plug in the ballast box?
what kit did you get? after you plugged in the ballast box did you plug the car into the box?
and i got some ebay xenon hid bulbs
i have the same issue... problem is that u bought the same kit i have probly.. there not dual hid,s meaning you only have low beams and i noticed that to.. when i unlock the car they dont come on this is because when u push the button it signals the high beams to come on so u can find ur car at night try this.... turn them on manually then turn on the high beams and look bet you have no light
they both work high and low beams but they have to be turned on manually
You put HID bulbs in your stock housings???? Wow this thread is retarded. Damn ricers.
i have a problem with my hids.. dont mean to threadjack.. but where do u hook the hot wire up to from the ballasts.??? i was going to put it in the fuse box but then i would have wires blocking the lid from going back on
whatd u do with the wires when put the fuse cover back on? Also I have the connector that looks like it goes in like a fuse.. sorry dont know the actual name of it haha
thanks
im gonna try that tough
thanks
you got the whole kit right?
nothing the way i hooked mine up, the wires follow the same path as the positive wire for the positive terminal on the fuse block. that big post that sticks out unscrews
Theres a pic on here somewhere. I dont remember whos tho. I will look around to try and find it.
Heres a link to a thread that you can see some pics of peoples cutoff's with HIDs in stock housings.
Last edited by 2007victoryred; 04-04-2009 at 09:20 PM. Reason: Automerged Doublepost
I have HIDs with projectors...not very special looking. Hmm...I don't really have the problem (with lights not coming on automatically)...recently my lights have been flickering though. I have to have the ballasts very secure to stop this.
If you read the thread there is another pic on the 2nd page. You should also read what ppl say about it that have them. Theres no need to be a smart ass either. I believe the pic on that page is actually of an rsx not a TL.
but either way lets not get this thread locked like all the other ones, you can never get everyone to agree on this topic
