HID's for fogs only. couple questions though
#52
man. i just helped a buddy put hids in his car a few days ago and would figure it would be easy and i would have to find a power source and all that.
time to start searching on here for a how to
#53
its cake.
plug in hids which is plug and play. 2 minute job. hardest job is mounting and making everything look clean which is easy as hell. relay you just run it to the post on the fuse box. your over thinking this lol
#54
atleast i have a heated garage and i can take my time doing it and do it right.
any tips i should probably know off hand befor i put them in after work today?
#55
only things i would suggest is make sure everything is sealed tight, and tucked away, also make sure ballasts are securely mounted thats about it.
good luck and be sure to post pics when done!
#56
Thanks dude. I definatly will post some pictures. Zip ties and 3m double sided tape should do the trick for tucking wires and mounting the ballast right?
#62
#64
wtf goes on there at TRS?? They sent me an H4 wiring harness! I have h11 bulbs! Ahhh this is driving me f**king crazy. Andrew at TRS is very cooperative and apoligized. I've been waiting 2 weeks for the effin things and now they send me the wrong harness! F.M.L.
#66
#67
I never ever will order HID's from TRS.idk how hard it is to send a box to a damn buisness with a suit number attatched. I got my wiring harness in the mail today after they sent me the wrong one last wensday so I finally got the new one today after TRS typed out the wrong address and I had to hunt the package down myself and just so happend to catch it before it was shipped back to TRS due to the wrong address. That woulda been the second time TRS woulda screwed it up.
But hey,ill have pictures up later if I have anyluck what so ever.
