HIDs and Radio
Old 05-17-2008, 04:59 PM
CCBalla10's Avatar
HIDs and Radio
Ok guys...basically my hids are connected in my 2nd gen projos and when the hids are on, the radio gets static. I thought maybe it was my ground wires, so i checked those and even scraped the paint off where i was grounding and this still doesn't help. Could it be from pulling the power from the boost post in the engine bay?
Old 05-17-2008, 05:31 PM
06blackSC's Avatar
hmm.....I wouldn't say its because you have the power wire run to your jumper post. I have two HID kits in my car (4 ballasts) and both are hooked up to the jumper post and i have no electrical interference what so ever. If you had a weak ground, i would think that the lights would either flicker or the ballasts wouldn't fire up at all.
I'm leaning towards exposed wiring or a possibly bad case seal on a ballast. Alot of power goes through those ballasts.
Old 05-17-2008, 05:32 PM
originaladrian's Avatar
do u have any audio mods? maybe upgrade ur ground wires. idk, never heard of tht happening before.
Old 05-17-2008, 06:01 PM
CCBalla10's Avatar
hmmm this is weird. I'm gonna check it one more time....its really annoying
no audio mods at all...all stock
Old 05-17-2008, 06:03 PM
steddy2112's Avatar
My goes static for a split second when they come on and that is it.
I have an aftermarket self powered sub and H/U though.
Old 05-17-2008, 06:17 PM
CCBalla10's Avatar
where exactly did you ground your wires??
Old 05-18-2008, 02:15 AM
Spun's Avatar
I have a 6000k kit in mine, I also have a full aftermarket audio system. My HID's are wired to the jumper post as well but I get no static from them. For the ground I used one of the bolts on the top of the struts, you know the one with the sticker that says ground. I just scraped the paint off.
What kind of balast are you using and what rating are your lights (4000k,6000k, ect)
Where did you mount the balast
Are the wires pinched up against the metal at all, check where you went through the frame to get to the headlights .
I would have to agree with the earlier post, you have a short somewhere or a bad balast
Old 05-18-2008, 10:38 AM
CCBalla10's Avatar
not my car...but i mounted mine in the same place
Old 05-18-2008, 10:56 AM
06blackSC's Avatar
Yup, same place i mounted my ballasts. My ground wire is attached to the chassis with a self tapping screw. I cleaned the area of the ground to bare metal before attaching the ground and coated it with battery terminal protector spray to ensure good contact for a long time. Is all this needed? no. Is this your problem? probably not. I'm still leaning towards bad ballast or exposed wires.
Old 05-18-2008, 11:07 AM
CCBalla10's Avatar
this is where i grounded the ballasts and they light up at night
Old 05-18-2008, 04:06 PM
Spun's Avatar
Looks like you did everything right, maybe you pissed the HID Gods off
Old 05-18-2008, 11:01 PM
CCBalla10's Avatar
haha i'm beginning to think i did. Do ballasts give off radio waves that would interfere with radio signals? I'm thinking maybe i got a pair of low quality ballasts
Old 05-18-2008, 11:17 PM
Preowner's Avatar
Terminal "protector" spray actually impedes conductivity so the terminals don't corrode. I've had a car not start because the stuff soaked down between the strap and battery terminal on a slightly loose strap. Something to keep in mind.
Old 05-18-2008, 11:23 PM
I'm too JDM for you
BLAZIN07SS's Avatar
i know radio interference with hids is a common problem with chrysler 300's but i have never heard a cobalt with this problem
Old 05-19-2008, 02:43 AM
EmperorJJ1's Avatar
is the static on all the time or just say radio stations?
Old 05-19-2008, 10:34 AM
CCBalla10's Avatar
well when i have my halos on everything works fine (radio, cd's). As soon as i turn my hids on, only the cd plays fine. Radio is only thing affected
Old 05-19-2008, 07:00 PM
EmperorJJ1's Avatar
means the ground on the cd player is bad... its grounding out thru the antenna causing radio to go bye bye. If u used a harness and did the ground that way i dont see why it would be an issue but reguardless swapping that ground should solve ur issue
Old 05-21-2008, 09:34 AM
CCBalla10's Avatar
but i have the stock pioneer system ???
Old 05-21-2008, 10:21 AM
EmperorJJ1's Avatar
???? lol the ground shouldnt be able to go bad or anything but if u walked in the shop thats what i would do. u can always sand a new piece of metal and throw a screw thru it and see if that helps. but i guarantee its an issue with a ground and ur antenna grounding out
Old 05-21-2008, 10:24 AM
CCBalla10's Avatar
where is the ground wire for the stock radio?
Old 05-21-2008, 02:17 PM
07blackss13777's Avatar
for the hid's do you need the hid harness b/c i bought the bulbs and i hope i see a diff haha
Old 05-22-2008, 02:15 AM
EmperorJJ1's Avatar
did u wanna try regrounding the HIDS first and see if that helps... stock ground for the radio is in the harness. Now that i sorta think about it unless u got a reverse harness i wouldnt mess with it
Old 05-22-2008, 09:59 AM
CCBalla10's Avatar
ok so i looked at the ground wires and they connect into the ballasts....how would i change out the ground wires? Looks like they go into the ballasts. It safe to take apart the ballasts? :S
Old 05-22-2008, 10:49 AM
Spun's Avatar
Now I may be wrong, but I think he is talking about where the HID's are grounded to the car . IMO you shouldn't be tearing that balast apart.
Old 05-22-2008, 10:52 AM
CCBalla10's Avatar
thank you sir. Ill check it tonight when i get home from work
Quick Reply: HIDs and Radio
