hooking up neon
Old 07-11-2011 | 02:30 PM
hopewillfall's Avatar
hooking up neon
Im looking to install red lighting to the inside of my front bumper so it shines on the intercooler making the graphic visible at night. Would it be alright to splice the wiring into the foglight wiring so the foglight switch controls both. I dont want to cut holes or add extra switches to the car. If this is a bad idea what would a better one be for installation?
Old 07-11-2011 | 02:41 PM
BooSSted's Avatar
I wouldn't power it directly from the fog light wiring. You can use a relay and run a power wire from the fuse panel and just use the fog light wire to turn them on via the relay. Same kinda way an HID relay harness works.
Old 07-11-2011 | 02:53 PM
Shibito's Avatar
I see you are in Michigan. Be careful if you do install this, it is illegal to have a red neon lit up on your car on a roadway.
Other then that, I agree with what BooSSted recommended.
Old 07-11-2011 | 03:14 PM
I had no idea, I appreciate that bit of info. Is it just red neon thats illegal or is it neon in general?
Old 07-11-2011 | 03:17 PM
EXsoccer1921's Avatar
red or blue on the front of your vehicle is illegal in pretty much every state iirc.
Old 07-12-2011 | 04:27 AM
EmperorJJ1's Avatar
yup impersonating a cop. hefty fine
Old 07-12-2011 | 04:31 AM
cmatthewb101's Avatar
In Ohio, you can have any color neon. But red and blue HAVE to be on the bottom of the car, and facing the ground. I'd think most states are the same.
Sean Cummings
03-09-2018 01:26 AM
jcalvin1126
10-26-2015 01:31 AM
OrangeCoba
10-01-2015 11:00 PM
InfraRedline
Drag Racing
35
09-29-2015 03:09 PM
