Horn electrical wires
Behind the lights. There is plenty of room down there anyway, and then the sound all goes out the front. That must be funny as hell to lay on the horn when going through the parking lot. Just make sure that you disable the honk when you lock or unlock the car, unless you want to make yourself that obvious.
yeah all 4 horns mounted infront of radiator, my grill hides them. currently hooked up to on/off switch, so i just need to disable stock horn, and run the stock horn +, to the + wire thats currently on my switch.
I saw the horn, but didnt look for wire. was hoping i can just unplug the horn, and cut, or pull the wire inside, so i dont have to run my (+) outside. If so, take it thru firewall plug hole? (thats where my airhose goes thru.)
