how can i repair a subs plastic
is there anyway u can repair the plastic in the middle of the sub would i have to use like apoxy or something i dont care how it looks as long as it works.
depends on exactly what your talking about and what sub it is... best case your talking about the dust cap... in which case you should be able to get it replaced for very cheap
much worse case you mean the cone itself which would depend alot on the material the sub is made from (very possible it could be an ez fix... but also as possible its unfixable)
if you mean the surround then ive herd of ways to fix it but its iffy.. honestly small surround holes shouldnt be that bad big gashes are much harder if possible
Since he said the plastic in the middle, I'm going to guess he means the dust cap. Take a picture and post it up here, it will make it a lot easier for us to figure out what your problem is and if you can fix it or need a new sub.
XStylus
Forced Induction
09-16-2015 06:19 AM
chris88z24
09-08-2015 01:55 PM
