How to change how long headlights stay on??
I wasnt exactly sure where to post this, but figured the headlights are electric?
So, is there a way to change how long the headlights stay on after you turn the car off? Tried in the settings menu in the DIC but didnt see anything regarding headlight times. Thanks!
Original Hayden Fanatic
You can't, they should go off about 10sec after you open/close the door.
You "could" just flip them to your parking lights then back to auto after you turn off the car if you wanted too.
but that will disable the auto headlights... Not sure if they re-enable at every start up or not because I don't mess with them, I like 'em.
no they come right back on next time you start the car. i do it bc i don't want the hid's on after i turn off the car. i usually do it before i turn the key to off.
importkiller
09-30-2015 07:18 PM
