How did you tap (+) for after market Amps?
![Question](https://www.cobaltss.net/forums/images/icons/icon5.gif)
How did you tap (+) for an after market Amp?
looking for some ideas, pictures would be nice if ya got um'
thank!!
thank!!
yeah i figured as much since its there in the trunk, i guess i mean more how did you connect to the battery, use that extra little threaded post or another method?
Yeah I went right to battery, and I just unscrwed the (+) terminal and hooked up my 2 amps to the exisiting spot and then screwed everything back. Having the battery in the trunk makes running the power wires for your amp or amps so much easier.
but now that us said that like that giant metal plate, maybe if i wanted a heftier connection i could drill a hole thru that metal plate and put a fatter bolt in there the sinch it down
