How to get better sound - bypass fact amp?
Hey guys, I recently put in a Pioneer 7" double din and a 12" JL W3. My speakers are being double amped now (by the headunit and factory amp). What is the easiest way to allow my headunit to amp the speakers and NOT the factory amp? I don't want to do the "Factory Amp Bypass" because I would not like to run a aftermarket amp to amplify my speakers. Thanks!
If you have a 07 or newer SS or SS/SC/TC then you shouldn't be double amping it. If you used an expensive harness then it converts the low signal that runs to the amp into RCA's so they can interface with the aftermarket deck.
Can't really help untill I know what your running (harness, year make of car, stock Pioneer sytem or base sytem)
i would have to agree.....plus you would be the first person i know of that has double amped speakers , from your pioneer system , and factory radio. my guess is your just intergrated into the factory amp!
its a 2005. and I used a PAC (dont remember the exact model). Double amping probably isnt the word but it gets really distorted after about Volume level 15. I usually listen to it at about 10-13 which isnt cranked but is decent. I like to have my music loud and clear though. Anyone know whats going on here or how I can fix this?
ya the pac is sorta a waste... but i know what your talking about and its a weird fix. Bet thing to do is use the rca outputs on the deck. If you can find some rcas that have seperate wires for pos and neg it would be best but if not just buy some cheap rcas and cut them. the outer shielding is neg and inner core is pos
probably like 100 spun. its the half ass module for us 05-06 guys but it doesn't really do anything other then give you acc. personally id rather save the 80 bucks and run a wire but whatever
run new wires to the speakers lol or find the stock amp and wire the in and the output harness together which is dumb, run fresh wire and mine as well pick up a nice alpine 4 channel amp with some new infinite speakers
Yes, it has Onstar.
Emperor, I have no idea what you are talking about! Lol, could you please clarify?
Could i unplug my factory amp, splice into my speaker wires running to that fact amp and run new wires from there to the deck? And leave my fact amp unplugged? this way I could put in the stock HU and plug in my factory amp when I decide to sell the car?
he is basically telling you to take your harness that has white,gray,green,and purple coming from the factory side and put rca ends on them, i have them where i work (bestbuy) the model number is rca8, this will power the factory amp, and in-turn the wires coming out of the aftermarket radio (same colors as above W,G,GR, P) will not be used you will just need to wire up power!
Could you post a link of the rca8? i cant find it!
What has everyone else done? Is everyone thats running a aftermarket deck also running a aftermarket amp for their speakers?
Last edited by 250motorsportz; 06-29-2009 at 11:00 PM. Reason: Automerged Doublepost
you can take some rcas and cut the rca end off leaving some slack to work with, when you strip the cut end yo should have two wires one positive and one negative! you need a total of 4 ends + and -
DANRICKARD
10-01-2015 12:08 AM
