humming through speakers
I just installed a new sand storm crossover to my system, and i am getting a wierd humming noise coming through the speakers, but only when the car is running. The noise is not heard at all when the car is just turned on enough for the radio to be on, only when the engine is actually started. The humming noise then makes sounds along with the car, such as acceleration, and opening and closing the power windows. I canged the ground to my 4 ch amp to a better ground (Where the battery grounds too) but the noise is still heard? any suggestions?
Find a better ground for the crossover
Get better RCA's if you don't have good ones in
Use bigger wires
The X-over alone does not draw that much power to effect your whole system, it sounds like you have a ground loop
Where is everything else that your running grounded to?
Use bigger wires
brickloaf
09-25-2015 09:10 PM
