i dont know what the f*ck im doing
Old 03-23-2011, 10:36 PM
thefinalgamer's Avatar
alright guys, i am just trying to hook up some light bars for my footwells. got the bars mounted, switched wires, and got them grounded, hooked a fuse tap into my fuse box, and nothing happened. my wiring is good. i just cant figure out what went wrong. i know im a noob so flame away lol
Old 03-23-2011, 10:38 PM
Bl4des's Avatar
where did you put it in the fuse box
Old 03-23-2011, 10:39 PM
Shibito's Avatar
Are you sure they're wired to a slot with a fuse? Only thing I can think of.
Chevycobaltss3's Avatar
well did you trn the key on, also did you tap into a fuse that has power once the cars turned on, or n the on position or if the keys in the acc position. Many ways to do it...
Old 03-23-2011, 10:40 PM
bbrewbaker's Avatar
You might of tapped a fuse that only has power when the key is on. Like the sunroof fuse.
Old 03-23-2011, 10:41 PM
i tapped it into the wiper fuse. and yes i turned the key on lol. wipers work but no lights. the lights worked fine when i tested them. the fuse tap in using has 2 slots. is there suppose to be 2 fuses in it?
Old 03-23-2011, 10:42 PM
Shibito's Avatar
Tap into the parking lights. That's what I did on my 2.4L
c4w18's Avatar
if you put 12v to one side of the switch and ground to the other side of the switch you burned your switch up lol.
Old 03-23-2011, 10:45 PM
padlock's Avatar
run a wire straight to your battery and put a switch on it.. thats what i did when i had my interior lights
i will try that tomorrow and see if it works
switch is fine lol. it just acts like its not getting power. i have a switch that has power in and out and a negative for the led on it.
cuebalt's Avatar
yes if theres 2 slots u gotta use 2 fuses, i think i used the same fuse tap as u, it should come with some did it not?
Old 03-23-2011, 10:46 PM
thedude411's Avatar
U need 2 fuses in the add a fuse thing. One fuse is for the wipers and the other will be for the lights. Throw in the proper fuse in the second slot and it should work
Old 03-23-2011, 10:48 PM
nope just came with the fuse tap. i will try it tomorrow. i thought i needed a 2nd fuse but i wasnt really sure.
Old 03-23-2011, 10:49 PM
cuebalt's Avatar
ok, ya put in a second fuse and it'll work, sounds like u did everything else right
Old 03-23-2011, 10:51 PM
ecot3c inside's Avatar
try turning your wipers on, if your lights come on then, then you should tap into something else.. i.e the ignition or parking lights.
Old 03-23-2011, 10:54 PM
LS6Rally's Avatar
My opinion would be to wire it to the Accessory Fuse, and it will act just like the Radio when the key is off. but its your call. sounds liek you do need two fuses. good luck.
do i need the same fuse as the wiper one?
Old 03-23-2011, 11:01 PM
cuebalt's Avatar
not really, but thats what i did when i did mine just because i didn't know what slot was for what lol
Old 03-23-2011, 11:04 PM
C_A_D88's Avatar
if your using the wiper fuse, then you put the wiper fuse in the bottom slot and thefuse for your leds or whatevr in the top slot, i dunno what amp fuse runs the wipers butif its just leds then you might not need a fuse as high, probably only a seven amp one will work but if it blows just up the fuse to a higher one lol
alright lol. i will give it a shot and we will see tomorrow. thank you all so much.
Old 03-23-2011, 11:05 PM
C_A_D88's Avatar
if you do the above and it doesnt work then your light bars are fucked, or somethingin your wireing is fucked
Old 03-24-2011, 07:52 PM
alright it was the fuse. thanks for all your help guys
Old 03-24-2011, 07:53 PM
Shibito's Avatar
Now that it's working, post up some pics!
Old 03-24-2011, 08:48 PM
i will snap some pics in the morning when i leave for class. to lazy right now lol.
Old 03-24-2011, 09:06 PM
C_A_D88's Avatar
n/p man. get some pics up lol
