i dunno whats wrong
Old 02-05-2009, 07:00 PM
EmperorJJ1's Avatar
do you have yourself a multimeter... test the subs and see what impedance (ohms) they read
also wiggle the ground post on the battery and see how loose it is. the stock cobalt terminals are pretty weird so if the ground is loose that might be what causing it to go into protect. a loose power terminal may also cause it but more likely to blow the fuse
Old 02-05-2009, 10:23 PM
blacksssc05's Avatar
it does stay in protect it just shuts off like it doesnt get anypower in my car
Old 02-05-2009, 11:31 PM
AdamJay's Avatar
test different speakers...might save you a lot of time
Old 02-06-2009, 01:44 AM
EmperorJJ1's Avatar
huh?
Old 02-06-2009, 02:15 AM
fzn14's Avatar
un plug both subs and see what happens....?
Old 02-06-2009, 02:25 AM
MBMCustoms's Avatar
i was having similar problems and it was all in the STOCK BATTERY AND STOCK TERMINALS. upgrade with a bigger battery and some new terminals after you have checked out all of your connections and checked to make sure the speakers are not blown. god this audio stuff sucks sometimes.
Old 02-06-2009, 08:42 AM
it doesnt stay in protect mode.... it just shuts off like it doesnt get any power in my car
Old 02-06-2009, 12:06 PM
EmperorJJ1's Avatar
then either the amps fucked or one of your connections. if its reading 12v on the pos/ground and 12v on the remote then amp is fucked
Old 02-06-2009, 03:18 PM
well just got it tested at an audio store and every thing was fine with the amp....i guess i better learn how to hook up ****
hacadacalopolis
10-28-2015 06:09 PM
no_ss
10-18-2015 11:58 PM
toledobalt
09-02-2015 07:04 AM
Quick Reply: i dunno whats wrong
