i need fog light switch info
i want to be able to keep my fogs on with my brights on basicly. i just need to know how many prongs are on the fog light switch and where the relay (or w/e it is) that disables the fogs when you turn your brights on is. however any info is helpfull
I do recall seeing a how to involving relays and a bunch of wiring - you end up about the same as adding aftermarket fogs and running your own switch / relay / wiring.
No idea why you would want high beams and fogs at the same time anyway but whatever floats yer boat
That would be in the bcm (body control module).
Black 07 Cobalt SS/SC - E85/Meth - Ported M62 - 2.5" pulley(23lb/305hp/275tq/7gph)/2.8" pulley(16lb/290hp/260tq/2gph) - 60lb inj - CAI/LS4 TB/Shrty Hdr/Ctls DP/2.5"exh - GM S2 Clutch - R1Concepts Slotted - 55w 6000k H/L - 35w 3000k fogs - full LED swap - 5% tint all around
z28addiction
09-28-2015 12:03 AM
