Ignition Wiring Question
Push button start and moved power outlet (UPDATE PICS: 56K NO)
Ok so I am putting in a push button start on my SS/SC. (Save the flaming I don't care what anyone thinks, I had it on my Mustang and loved it)
Anyway, I have everything mounted and ready to go, have power and ground to my button but I don't know which wire I need to cut to wire for the ignition. I have the directwire wiring list, which is wrong from what I can tell. I have no C4 connector. The only light grey connector I have is on the back of the BCM and has only 1 yellow wire in it. This wire has a 12v signal with the ignition in the on position and does not change when you turn the key to the start position.
I read somewhere that our PCM turns the starter when the ignition wire has 12v and the accessory wire has 0. Does that mean our ignition wire is always 12v when the car is in the on position and turning the key to the start position only removes power from the accessory wire? or am I missing a wire that gets a 12v signal only when the switch is in the start position?
Any help would be great.
Oh and I have taken pics of everything so far and will post them when I am done.
well although noone seems to be able to help me with the wiring of the ignition I have everything mounted and thought I'd post some pics.
This is the button I'm using:
It fits a "standard" cigarette lighter opening but unfortunately ours is much larger so I had to make a mounting plate to go behind the console:
I moved the power outlet down to the end of the shifter console opposite the existing one which required a new hole and some modification to the plastic underneath:
This is the finished look:
Now if I can just figure out the wiring...
i can E-Mail you PCM and Ignition switch connector pinouts if they would help. How is this going to work? It seems you will still need the key in the run position for the car to run. Why not just turn the key? Do you have a kit that eliminates the ignition switch?
Dennis
Dennis
No I don't have anything that eliminates the ignition switch. I want the car to stay "secure" in that it needs the key. Yes I will still have to turn the key to the run position but I am trying to find a way to disable the ignition switch's ability to start the car and require the push button to do it.
I had this same setup on my Mustang and loved it. I think I might have it figured out. The white wire in the ignition harness is for the ION style passkey. It flows 4.41v when the key is in the run position and drops to 3.63v when the key is turned to the start position. This is what the system sees as a resistance code(R-Code). If I cut that wire and find out the amperage flowing through it then I can determine the size resistor I will need in order to drop the correct amount of voltage... Ohms law R=E/I. With that I should be able to wire a relay or two so that I can cut that wire, have it connected through a relay when the accessory power is on and then have that relay disengage and connect a second output when the push button is switched. Therefore having 4.41 volts flowing in the run position but when I push the button drop it to 3.63v and trigger the starter.
I haven't tested all this yet as I am still working out the wiring but I am working on it.
If I could find out where the white wire from the ignition harness, pin 5 I think runs into the BCM that would be great. That seems to be the one piece of information I am missing. I can cut the wire in the column but it would be easier, and cleaner, to do it all behind the center console, at the BCM.
Here are the BCM connector pinouts. Sorry it's a little hard to read, when I copy info out of Service Information it isn't formated properly. hope this helps you.
Dennis
Document ID# 1597745
2006 Chevrolet Cobalt
Computer/Integrating Systems Connector End Views
Connector 1: Body Control Module (BCM) C1
Connector 2: Body Control Module (BCM) C2
Connector 3: Body Control Module (BCM) C3
Connector 4: Body Control Module (BCM) C4
Connector 5: Data Link Connector (DLC)
Connector Part Information
OEM: 15393122
Service: 88987847
Description: 72-Way F Micro 64 (GY)
Terminal Part Information
Pins: 1, 6 -- 8, 13 -- 20, 22, 26, 33, 35, 36, 44, 47, 51, 54, 55, 57, 60 -- 68, 70
Terminal/Tray: 15359541/4
Core/Insulation Crimp: M/M
Release Tool/Test Probe: 15381651-2/J-35616-64B (L-BU)
Pins: 31
Terminal/Tray: See Terminal Repair Kit
Core/Insulation Crimp: See Terminal Repair Kit
Release Tool/Test Probe: See Terminal Repair Kit
Body Control Module (BCM) C1 Pin
Wire Color
Circuit No.
Function
L-BU/BK
747
Left Rear Door Ajar Switch Signal (Sedan)
2-5
Not Used
WH
682
Door Lock Lock/Unlock Signal
WH
682
WH
1080
Park Lamp Relay Control
9-12
Not Used
13
PK
849
Brake Fluid Level Sensor Signal
14
L-BU
1134
Park Brake Switch Signal
YE
5199
Run/Crank Relay Coil Control
WH
193
Rear Defog Relay Control
17
D-BU
Right Front Turn Signal Lamp Supply Voltage
18
D-GN
5060
Low Speed GMLAN Serial Data
19
TN/WH
746
Right Front Door Ajar Switch Signal
20
L-GN/BK
748
Right Rear Door Ajar Switch Signal (Sedan)
Not Used
22
GY/BK
745
Left Front Door Ajar Switch Signal
23-25
Not Used
26
L-GN
1478
Coolant Level Switch Signal (LSJ)
27-32
Not Used
D-GN/WH
1135
A/T Shift Lock Control Solenoid Supply Voltage
34
Not Used
35
L-BU
14
Left Front Turn Signal Lamp Supply Voltage
36
D-GN
5060
37-43
Not Used
44
TN/WH
1969
Headlamp High Beam Relay Control
45-46
Not Used
47
YE
196
Windshield Wiper Motor Park Switch Signal
48-50
Not Used
51
D-GN
113
Windshield Wiper Switch Signal
52-53
Not Used
54
YE
317
Fog Lamp Relay Control (T37)
55
OG/BK
744
Rear Compartment Lid Ajar Switch Signal
56
OG/B
737
Rear Compartment Lamp Control
57
BN
253
Rear Compartment Release Relay Control
58-59
Not Used
60
TN
28
Horn Relay Control
61
BK/WH
1251
Ground
62
RD/WH
1240
Battery Positive Voltage
63
GY
596
5-Volt Reference-1
64
BK/WH
751
Ground
65
TN/WH
1704
Low Reference
66
GY/BK
1798
Low Reference (Sedan)
67
YE/BK
61
Low Reference
68
WH
5075
Current Sensor Signal
69
Not Used
70
D-GN/WH
636
Ambient Air Temperature Sensor Signal
71-72
Not Used
OEM: 15393121
Service: 88987848
Pins: 1 -- 5, 9, 10 -- 12, 14 -- 17, 19, 20, 26, 38, 44, 47, 51, 54 -- 58, 61, 62, 66 -- 69, 72
Pins: 70
Body Control Module (BCM) C2 Pin
Wire Color
Circuit No.
Function
BN/WH
2500
High Speed GMLAN Serial Data (+)
TN/BK
2500
YE
Headlamp Switch Signal
PU
524
Headlamp Dimmer Switch High Beam Signal
BN/WH
301
Park Lamp Switch On Signal
6-8
Not Used
WH
111
Hazard Switch Signal
TN
1576
Rear Compartment Lid Release Switch
D-GN
264
Security Indicator Supply Voltage
12
TN/WH
1455
Keyless Entry Program Enable Signal
13
Not Used
14
TN
28
Horn Relay Control
WH
103
Headlamp Switch Headlamps On Signal
OG
192
Front Fog Lamp Switch Signal (T37)
17
PU/WH
549
Headlamp Switch Headlamps Off Signal
18
Not Used
19
BN
2501
High Speed GMLAN Serial Data (-)
20
TN
2501
21-25
Not Used
26
D-GN
44
Instrument Panel Lamp Dimmer Switch Signal
27-37
Not Used
38
D-GN
5060
39-43
Not Used
44
L-GN/BK
1137
DRL Ambient Light Sensor Signal
45-46
Not Used
47
YE/BK
1138
DRL Ambient Light Sensor Low Reference
48-50
Not Used
51
BN
1356
Flash To Pass Switch Signal
52-53
Not Used
54
L-BU
20
Stop Lamp Supply Voltage
55
Not Used
56
WH
1390
Off/Run/Crank Voltage
57
GY
112
Windshield Wiper Switch Signal 1
58
PU
719
Low Reference
59-60
Not Used
61
GY
1884
Cruise Control Switch Signal (K34)
62
WH/BK
1073
Ignition Key Resistor Signal
63-65
Not Used
66
YE/BK
1418
Left Rear Turn Signal Switch Signal
67
D-GN/WH
1419
Right Rear Turn Signal Switch Signal
68
L-BU
292
Rear Defog Switch Signal
69
L-GN
66
A/C Request Signal
70
Not Used
71
PU
5234
Passenger Seat Belt Reminder Lamp
72
WH
193
OEM: 15404825
Service: 15404825
Description: 41-Way F Metri-Pack 280, 800 Series (RD)
Body Control Module (BCM) C3 Pin
Wire Color
Circuit No.
Function
A1
TN
294
Door Lock Actuator Unlock Control (AU3)
A2
TN
294
TN
294
Door Lock Actuator Unlock Control (AU3) (Sedan)
A3
D-BU/WH
149
Courtesy Lamp Supply Voltage
A4
GY
295
Door Lock Actuator Lock Control (AU3) (Driver)
GY
295
Door Lock Actuator Lock Control (AU3) (Passenger)
A5
GY
295
GY
295
Door Lock Actuator Lock Control (AU3) (Sedan)
A6
Not Used
A7
BN
Park Lamp Supply Voltage
A8
PK
339
Run/Crank Ignition 1 Voltage (UQ3)
A9
YE
18
Left Rear Stop/Turn Lamp Supply Voltage
A10
GY
157
Courtesy Lamp Control
A11
Not Used
A12
D-GN
19
Right Rear Stop/Turn Lamp Supply Voltage
B1
TN
694
Driver Door Lock Actuator Unlock Control
B2
Not Used
B3
RD/WH
1240
RD/WH
1240
B4
Not Used
B5
BN
Accessory Voltage
BN
Accessory Voltage (L61/LE5)
B6-B7
Not Available
B8-B11
Not Used
B12
GY
Instrument Panel Lamp Supply Voltage (LSJ) and (J41)
B12
GY
Instrument Panel Lamp Supply Voltage (L61/LE5)
GY
C1-C2
Not Available
C3
D-GN
1301
Retained Accessory Power Fuse Supply Voltage
C4
Not Used
C5
D-GN
801
C6-C7
Not Available
C8-C11
Not Used
C12
OG
228
Windshield Washer Pump Control
D1
RD/BK
142
D2
Not Available
D3
Not Used
D4
RD/WH
840
D5
D-GN
801
D6
PK
739
Ignition 1 Voltage
D7
PK
1339
Ignition 1 Voltage
PK
1339
Ignition 1 Voltage
D8-D9
Not Used
D10
RD/BK
442
D11
Not Used
D12
RD/WH
242
OEM: 15356603
Service: 88988776
Description: 68-Way F Metri-Pack 280 Series (L-GY)
Body Control Module (BCM) C4 Pin
Wire Color
Circuit No.
Function
A1
RD/WH
640
Battery Positive Voltage (UQ3)
RD/WH
640
A2-A12
Not Used
B1
OG
228
B2-B12
Not Used
C1
RD/WH
1440
C2
GY
GY
C3-C5
Not Used
C6-C7
Not Available
C8
BN
Accessory Voltage
C9-C12
Not Used
D1
RD/WH
1040
D2
Not Used
D3
YE
5199
Run/Crank Voltage
D4
BN
141
Ignition 3 Voltage
D5
Not Used
D6-D7
Not Available
D8-D9
Not Used
D10
RD/WH
1140
RD/WH
1140
D11-D12
Not Used
E1
RD/WH
140
E2-E5
Not Used
E6
PK
439
Ignition 1 Voltage
PK
439
Ignition 1 Voltage (Coupe) (TV5)
E7-E11
Not Used
E12
BK/WH
651
Ground
F1
RD/WH
1540
RD/WH
1540
F2
GY
F3
GY
GY
F4
PK
339
Ignition 1 Voltage
PK
339
Ignition 1 Voltage
F5
PK
339
Ignition 1 Voltage
PK
339
Ignition 1 Voltage
F6
PK
339
Ignition 1 Voltage
F7-F8
Not Used
F9
PK
1539
Ignition 1 Voltage
PK
1539
Ignition 1 Voltage
F10-F12
Not Used
OEM: 15317575
Service: 15317575
Description: 16-Way F Metri-Pack 150 Series (BK)
Data Link Connector (DLC) Pin
Wire Color
Circuit No.
Function
D-GN
5060
D-GN
1049
PCM Class 2 Serial Data (LSJ)
Not Used
BK
550
Ground
BK/WH
1051
Signal Ground
TN/BK
2500
7-13
Not Used
14
TN
2501
Not Used
RD/WH
40
Dennis
OEM: 15393122
Service: 88987847
Pins: 31
Wire Color
Circuit No.
Function
L-BU/BK
747
2-5
Not Used
WH
682
WH
682
WH
1080
9-12
Not Used
13
PK
849
14
L-BU
1134
YE
5199
WH
193
17
D-BU
18
D-GN
5060
19
TN/WH
746
20
L-GN/BK
748
Not Used
22
GY/BK
745
23-25
Not Used
26
L-GN
1478
27-32
Not Used
D-GN/WH
1135
34
Not Used
35
L-BU
14
36
D-GN
5060
37-43
Not Used
44
TN/WH
1969
45-46
Not Used
47
YE
196
48-50
Not Used
51
D-GN
113
52-53
Not Used
54
YE
317
55
OG/BK
744
56
OG/B
737
57
BN
253
58-59
Not Used
60
TN
28
Horn Relay Control
61
BK/WH
1251
Ground
62
RD/WH
1240
63
GY
596
5-Volt Reference-1
64
BK/WH
751
Ground
65
TN/WH
1704
Low Reference
66
GY/BK
1798
67
YE/BK
61
Low Reference
68
WH
5075
69
Not Used
70
D-GN/WH
636
71-72
Not Used
OEM: 15393121
Service: 88987848
Pins: 70
Wire Color
Circuit No.
Function
BN/WH
2500
TN/BK
2500
YE
PU
524
BN/WH
301
6-8
Not Used
WH
111
TN
1576
D-GN
264
12
TN/WH
1455
13
Not Used
14
TN
28
Horn Relay Control
WH
103
OG
192
17
PU/WH
549
18
Not Used
19
BN
2501
20
TN
2501
21-25
Not Used
26
D-GN
44
27-37
Not Used
38
D-GN
5060
39-43
Not Used
44
L-GN/BK
1137
45-46
Not Used
47
YE/BK
1138
48-50
Not Used
51
BN
1356
52-53
Not Used
54
L-BU
20
55
Not Used
56
WH
1390
57
GY
112
58
PU
719
Low Reference
59-60
Not Used
61
GY
1884
62
WH/BK
1073
63-65
Not Used
66
YE/BK
1418
67
D-GN/WH
1419
68
L-BU
292
69
L-GN
66
A/C Request Signal
70
Not Used
71
PU
5234
72
WH
193
OEM: 15404825
Service: 15404825
Wire Color
Circuit No.
Function
A1
TN
294
A2
TN
294
TN
294
A3
D-BU/WH
149
A4
GY
295
GY
295
A5
GY
295
GY
295
A6
Not Used
A7
BN
A8
PK
339
A9
YE
18
A10
GY
157
A11
Not Used
A12
D-GN
19
B1
TN
694
B2
Not Used
B3
RD/WH
1240
RD/WH
1240
B4
Not Used
B5
BN
Accessory Voltage
BN
B6-B7
Not Available
B8-B11
Not Used
B12
GY
B12
GY
GY
C1-C2
Not Available
C3
D-GN
1301
C4
Not Used
C5
D-GN
801
C6-C7
Not Available
C8-C11
Not Used
C12
OG
228
D1
RD/BK
142
D2
Not Available
D3
Not Used
D4
RD/WH
840
D5
D-GN
801
D6
PK
739
Ignition 1 Voltage
D7
PK
1339
Ignition 1 Voltage
PK
1339
Ignition 1 Voltage
D8-D9
Not Used
D10
RD/BK
442
D11
Not Used
D12
RD/WH
242
OEM: 15356603
Service: 88988776
Wire Color
Circuit No.
Function
A1
RD/WH
640
RD/WH
640
A2-A12
Not Used
B1
OG
228
B2-B12
Not Used
C1
RD/WH
1440
C2
GY
GY
C3-C5
Not Used
C6-C7
Not Available
C8
BN
Accessory Voltage
C9-C12
Not Used
D1
RD/WH
1040
D2
Not Used
D3
YE
5199
Run/Crank Voltage
D4
BN
141
Ignition 3 Voltage
D5
Not Used
D6-D7
Not Available
D8-D9
Not Used
D10
RD/WH
1140
RD/WH
1140
D11-D12
Not Used
E1
RD/WH
140
E2-E5
Not Used
E6
PK
439
Ignition 1 Voltage
PK
439
E7-E11
Not Used
E12
BK/WH
651
Ground
F1
RD/WH
1540
RD/WH
1540
F2
GY
F3
GY
GY
F4
PK
339
Ignition 1 Voltage
PK
339
Ignition 1 Voltage
F5
PK
339
Ignition 1 Voltage
PK
339
Ignition 1 Voltage
F6
PK
339
Ignition 1 Voltage
F7-F8
Not Used
F9
PK
1539
Ignition 1 Voltage
PK
1539
Ignition 1 Voltage
F10-F12
Not Used
OEM: 15317575
Service: 15317575
Wire Color
Circuit No.
Function
D-GN
5060
D-GN
1049
Not Used
BK
550
Ground
BK/WH
1051
Signal Ground
TN/BK
2500
7-13
Not Used
14
TN
2501
Not Used
RD/WH
40
