innovate LC1 CB gauge...
ok here's what i got for it so far, the instructions are not to specific so im not to sure how to go about this, there is something bothering whcih i will adress in a sec
LC1 6 cords:
red: switched pwr source: IGN fuse
blue: heater ground: ground with "white" cord
white: system ground: ground with blue bord
yellow: analog out 1: f this one and just tape it so it doesnt contact anything
brown: analog 2: connect to gauges "white" wire
black: calibration wire: connect LED and push switch, than run to ground
now i dont know how that goes, the LED displays the stutus of the Lc1; now do i wires it like this:
A)gauge>wire>led>push style button>grd
B)gauge>wire>push button> led>grd
????????????????????????? the button is a simple push style u push it and it comes back up, u push it, its grounds off, and when u let go it stops grounding off
also if anyone knows the specific way to calibrate the damn thing, the instructions blow...i believe i got it right
hit the button>wait 2 minutes>plug in wideband o2>wait 2 minutes>put wideband o2 into wideband bung on dp>good to go
also i know to check the lc1 to make sure the 0-5v output is set to the defaults, just the calibration wire, and process i need assurance about, i will installing this thing tommorow
thats what the push button LED thing looks like
LC1 6 cords:
