installing gauges in our cars (2.4)
well i just bought a few gauges, but i want to know what the best way to wire them up is. i want them to come on and go off when i turn the car on so i think im looking for a switched source, what would the best switched source in our car be?
yea basically anything with ignition. if you go to the how-to guide one of the top theads is how to wire in an electrical oil pressure guage for a 2.2. it should be pretty much the same for the 2.4, that might help you out.
ok i checked that thread and basically he went off the ignition fuse? said something about adding fuses in? this wiring stuff is kinda confusing to me
the add a fuse thing is something you buy that basically lets you plug two fuses into one. the add a fuse plugs into where the original fuse was, then you plug the orginal fuse plus the fuse your adding into the add a fuse. you can get them at any autozone, pepboys etc. for a couple bucks. that was probably a confusing explanation but its not too complicated once your actually looking at the stuff haha.
X2 sunroof fuse
yea thats another good one. i think most of those type of fuses are in the fusebox thats inside the car as well so thats one less wire to run through the fire wall lol.
Thats what I used to power my relay for the neons and amp. pic is worth a 1000 words though http://www.partsexpress.com/pe/showd...number=071-580 and when checking the circuits make sure the drivers door isn't closed
X2 sunroof fuse
X2 sunroof fuse
It depends on the amps. If you are going to pull a lot of amps get a relay. The relay is basically a switch that turns on electronically. Normal pos and negative hook up and then you have Normally closed, normally open, and common (when not energized). You run straight battery power to common, and then connect all of your stuff to normally open. When you turn on the car the power from your fuse box tap turns on the relay and makes it close passing power to you gauges.
Of course you will have your inline fuses that came with the gauges in there.... I also have one near the battery
you can pull 30 amps through 1 circuit in the fuse box, 15 for the sunroof and 15 for everything you add to the add a fuse. Your gauges shouldn't pull anywhere near that, but it will tell you how many amps they pull in the spec sheet that came with them.
do you have a picture of this relay?
what would i hook each of the gauges to...like which fuses in the fuse box?
The relay would only get switched power from the factory fuse panel, you gauges would be using battery power. Read the first part of this and if you still have questions we will go from there.
http://www.r1200gs.info/howto/relay.html
I know the example is for a bmw motorcycle but same difference
Next week we will cover initiating two way communication, triggering a pc software program to send out a wireless pager alert and lighting a hospital hallway dome light and a buzzer all by pushing 1 button...... then maybe a Job installing Nurse call systems in hospitals and nursing homes.....
the bosch that Scot used in his write up is a good one, any local auto parts store will have them, it is a must for fog light installs. Look in the electrical section by the fuses, brand doesn't really matter, the bosch one is just smaller. The upside to doing it this way is that you will not have to tamper with the factory wiring, preserving your electrical warranty, if you have an electrical issue just pull the add a fuse before you take it to the dealer.
