Installing Second Pioneer Sub
ok so i don't wanna go too crazy with a system but i do want a little bit more bass. i like the sound of the pioneer sub so i want to add another one in on the other side. i am going to try to find a stock subwoofer from another cobalt . But i need to know if i can wire it by tapping into the plug that goes into the subwoofer. I will make another box custom to fit into the other side and then carpet everything to match or possibly make a fibreglass enclosure that looks the same as the stock one but reversed. So if you could give me some suggestions that would be great. and btw where is the amp for our stock system?
Thanks
Chris
Thanks
Chris
You should be able to tapp it but you might want to get another amp, either another small 1 to push the other sub or just 1 big 1 to replace the stock 1 and push both. Im not surre what the stock one pushes but i used a 460 watt dual amp and pushed 2 MTX thunder
4000`s and it sounded pretty nice.
Thanks
Chris
Thanks
Chris
Originally Posted by Bandit2941
What do you mean by tapping it? Just T'ing in to the existing sub wiring and hooking the new sub up that way (in parallel with the original)? If that's the case then you will probably hurt the stock amp since you will be cutting the impedance in half.
i've installed many systems and also spoken with several of my friends who own competition stereo stores and everyone's opinion is that you can tap into thos wires to install another sub but you may end up splitting the power between the two subs so the sound may not be as good. i have 3 concept 12's and a 1200 watt amp i'm going to put in my car so i was going to attach an output converter to those wires since i was keeping my stock head unit. just need to find the time..ya know
Thanks
Chris
Thanks
Chris
the amp is under the drive side dash. its tiny and grey
It's fine to tap into those wires to hook up an output converter like you're going to do. But, if you're going to just run them into a new sub, it won't do much good sound wise and like I said it will probably end up hurting the factory amp due to half impedance.
i don't think it will hurt the amp. IMO 2 subs runing off the same amount power as one will get half the amount of power and end up hurting the sound quality/volume.
That's just it, it doesn't get half the amount of power when you run 2 subs in parallel. When you run the subs in parallel the amp sees half the impedance and puts out MORE power (for example my Alpine is 400w RMS @ 4 ohms but 600w RMS @ 2ohms, so if I had one 4 ohm sub it would get 400 RMS, but if I had 2 4 ohm subs in parallel they would get 300 each) then it originally did, and if it wasn't designed for it (which the factory stuff probably isn't) it'll get hurt when the volume is cranked.........
I do think there's a good chance it will hurt the amp. If impedance doesn't matter, why can't you just run as many subs in parallel as you want and keep halving the impedance?
LOL whatever dude you obvously think you know more than the people who do this **** for a living so i'm not going to waste my time arguing with you. soooo that said have a nice evening
Maybe you should check out the parallel impedance calculator at this site: http://www.the12volt.com/caraudio/boxcalcs.asp
If you put 2 4 ohm speakers in parallel the load the amplifier sees is 2 ohms. If you knew anything about ohm's law and amplifiers you would know that a 2 ohm impedance will cause the amplifier to put out more power then a 4 ohm impedance. But if the amplifier is not stable for the ohms you try to run it at, you will likely hurt it or put it in protection mode. You might also check out the info here and pay special attention to the line that says "Please check to see that the overall impedance load is compatible with your amplifier."
Originally Posted by BlueSS-supercharged
dude thats a bad idea, you cant run subs like that across from each other and expect it to sound good. the distance is too great and it would sound horrible
Hooking another sub up in parallel will kill that amp, and may cause a fire with the small power wire. You are going to pull more power than that amp is able to handle and I would doubt that a factory amp would have thermal overload protection because they don't plan on it being used for anything other than the factory connection...which is what could cause a fire. It will just heat up and never shut off, like most aftermarket amps will.
Just for future knowledge fuses on your power line are not to protect your amps that you have it hooked into it is to protect the wire and stop it from burning through your car. 0 guage could easily heat up hot enough to melt right through the frame of your car if the amprage was uncontested by something like a fuse. I use to wreck chace and have acutally seen this happen when the wire was pinched off at one end where the fuse was and it was still connected to the battery.
You do have the option of hooking your second sub in series. This would send an 8ohm load back to your amp. That will half the power that your amp puts out. So, for example if it was giving out 200 W to a single sub in 4 ohms. It would now give out 100 W to 2 subs in 8 ohms. With this set up you would not have to worry about overheating and bunning something up. This is your only option to use your factory amp on 2 subs. They will loose volume and clarity if you do this so it defeats the purpose.
I would get a small truck specific after market sub and aftermarket amp and just install them both in place of the existing factory sub. The truck specific is because the enclosure is fairly small so a sub made for small enclosures would do better in there with out having to add spacers.
also ment to say cancels each other out
They probably will not cancle each other out because there will be a fraction of a delay in one of them because of the impedance of the wire. It is low but it still has some which will give some delay. The waves would have to be exact opposite to notice an audible cancelation. This is nearly imposible to do. In theory cancelation can happen but in practice it would be very rare.
Is there anyone that has a stock sub with enclosure that would be willing to sell, and if so how much and where are you located
i could possiby have a stock sub, im located in massachusetts. i don't know what they go for so if i look around im sure i can hook u up with a price if my car is totaled cuz its no use to me
