Jensen VM9511TS DVD advice
http://www.crutchfield.com/S-R2J9jru...=110VM9511#Tab
I found this at crutchfield for a good price. Do you think it's worth it? Also is jensen any good and how would I going making the dvd play while the cars in motion? Thanks
so it's worth the money.. Do you know if the headunit has pigtail rcas in the back if you know what i mean. Also do the tv antennas have to be on the outside?
by pigtails i mean rca wire coming off the back of the headunit then having the female connectors at the end of the wire. Or just it just have the rcas right in back of the headunit. thanks.
Originally Posted by hardtocope
is it illegal to bypass the dvd so it plays while driving?
LIke he said its illegal. But its ok to have it open in the cd or fm mode while driving. So if you get pulled over just switch it to the fm mode or cd mode and you will be fine.
what if u were ever in a serious accident adn they found that the dvd player is illegal and can play while driving? U think they would look at somethign like that?
It's a very good unit. I currently have one for sale if anyone's looking....and screw the Ebrake/toggle switch, do this:
1) Insert the DVD and you'll get the blue screen.
(If you have more than one tv, the unit itself will have the blue screen but the additional tv's you have plugged in will NOT, they will show the dvd menu. Thus you will be able to see the hidden menu on the additional screens after inputting the code, but not on the main unit because of its blue screen.)
2) On the main remote, push stop twice and then 1, 2, 6, 4
3) Push the joystick on the unit SOUTH twice and then click it once.
4) Press SYS SETUP on the main remote twice to save your settings
That's the factory overwrite code that vendors use to display it on their shelves w/o an ebrake to stop them :]
Original Hayden Fanatic
If its once, that is cool, but if its every time, screw that the switch/ebrake bypass is way easier
once only, permanent........it saves even when ignition is off :] have fun
oh and i forgot to mention, it allows you to choose region codes and allows you to watch pirated dvds....just enter that sequence again and you'll see a menu with those options
in that case, awesome hack!!
yea, just hope someone has a jensen dvd player here that can utilize it....besides me....unfortunately i just got the newest model and they don't have a bypass code like that yet...But i plan to go to my local audio shop and since I'm good w/ the guy there asking him to call in for a code for a "display of the new model" so I can use it myself heh
NoBalt123
09-04-2015 07:10 AM
