Kinetik HC1400
Kinetik HC1400
Hi, Im new here, I got a question, does anyone know if a Kinetik HC1400 will fit in the stock battery compartment of a 2007 Cobalt Lt, I measured it and it looks like it might be a bit too tall, but im not sure.
Thanks
Thanks
Damn, thats what i figured, do you have any other suggestions that i can use like will the hc1200 work, i am curious b_faulk where do you have yours, i want to remove the stock battery and replace it with a kinetik i wanted the hc1400, do you think i can add a hc800 with the stock battery, because i have an old school hifonics zeus VIII and my headlights dim like a bitch, any help would be appreciated, i want to preserve my trunk as much as possible i only have one 12 fi Q in a sealed box.
ok i am getting The HC1400 , and i am putting it in the place that b_faulk refrenced, now i am trying to upgrade the big 3 and i am having trouble getting to the alternator to upgrade the wire, my question is can someone please tell/show me how to get to the alternator wire. thers alot of stuff in the way and i do not want to damage anything.
Thanks again!
Thanks again!
Just carefully remove the things that are in the way. You will have less time just getting things out of the way than trying to fish wires and stuff around all that crap. It's been a while since i did mine i can't remember if i removed anything or not.
Thanks again!
Thanks again!
So thats the wire going from the positive terminal of the battery to the under the hood fusebox?, with the red cover over it under the hood, is that the whole wire, is at a big job to replace that wire, would 2 gauge be large enough or should i go 1/0, thanks for all your help.
ya normally the bat is under the hood and the wire goes from the alt to the bat then a seperate wire to the fuse box. in the cobalt with the batt in the trunk the alt wire goes to the fuse box and then to the stock bat. replacing the stock alt to fusebox probably wont do as much as the hassle is worth. Oh and my theory with wiring is do the biggest you can afford/fit now that way you dont have to mess with it ever again. Its your decision thou.... 2g is ~half 1/0 so with the larger wire your capacity is doubled and the resistance goes down. 1/0 is obviously better but its also more expensive so in the end its up to you. Just dont get any copper clad aluminum crap. Ive never seen the point of even having it
I have 2 (1400's) and they fit perfectly into the well on either sid eof the trunk. Right where the stock sub would be and across from it.
I think the batt fits under where the stock one goes but thats before to attach the cables and put the bolt in, IDK I could be wrong though, it does seem a alot taller than the stock one
#cobalthoes
I used some of the 1/0 I had and made a better ground for the battery other then that nope.. I havent even got time to do the big 3 yet and this is keeping my voltage pretty good ive only seen it drop to 13.1 and I have a T1000bd and a p400.4 running off it.. And a power hungry Fi Bl 15"
