LED Headlights - Modded Depo Gen4
Old 12-16-2013, 02:20 PM
warrenb213's Avatar
The lumens are PER BULB.
I've also know exactly which CREE LED chip's they are using, they do in fact perform as advertised.
HID's are generally also rated on a per bulb, 35w HID bulbs can generally range from a "lower end" 2200lm each to 3500lm each on the "higher end". Without a doubt, with a high end 35w HID's you'll push about 2600lm total more in comparison to LED or TOP-END halogens. 2600lm does make a difference, but not so much that it rule out the use of LED's, as the LED's are on the very highest end of halogen output (and consider the best halogen's don't usually have a long life either.). People don't get blinded, and you can see great!
bigdeertz
11-17-2016 09:41 AM
Builttss
10-04-2015 10:21 AM
nathan112i
09-30-2015 07:12 PM
09-26-2015 06:44 PM
jonnycat
09-19-2015 12:58 PM
Quick Reply: LED Headlights - Modded Depo Gen4
