Line out converter???
Old 07-30-2008, 05:18 PM
07touringcoupe's Avatar
I have a line out converter but im lost, where does the wire hook up at? It's 2 white wires one with a black strip, 2 grey wires one with a black strip and a black wire. The one i got didnt come with directions. Does someone how to hook this up???
Old 07-30-2008, 05:29 PM
nikebaseballx00's Avatar
white wire without black stripe- positive left speaker wire
white wire with black stripe- negative left speaker wire
grey wire without black stripe- positive right speaker wire
grey wire with black stripe- negative right speaker wire
black wire- ground, u dont really need this but i would use it to be safe
Old 07-30-2008, 05:33 PM
So where does the remote amp wire go?
And how do i know what wire is what in the stock unit
Old 07-30-2008, 05:38 PM
the remote amp wire should go to the back of ur headunit if its an aftermarket
if u have a stock headunit, run the remote wire to a fuse under the passenger side of the shifter
u dont run the line out converter to the stock headunit, u just tap into ur rear speaker wires, u can find these just kinda hangin in the trunk, im not sure which is which but i dont think it matters, CORRECT ME IF IM WRONG SOMEONE if it really matters
Old 07-30-2008, 05:43 PM
iight so i can leave the line out converter in the truck and still have bass?
Old 07-30-2008, 05:45 PM
what are u using the amp for? speakers or subwoofers
Old 07-30-2008, 05:50 PM
im using the amp for subwoofers
Old 07-30-2008, 05:51 PM
ok, so just tap into the wires, dont cut them
then from the line out converter, hook up ur RCAs to the amp very simple
Old 07-30-2008, 05:53 PM
So i do not have to go behind the headunit right?
Old 07-30-2008, 06:00 PM
nope, just run the remote wire to the fuse box which is on the passenger side below the cup holders and radio area
Old 07-30-2008, 06:12 PM
ok i just looked for wires right in the truck and i didnt see nothing. I only saw connectors with wires but i didnt see the colors i need, Which ones do i need?
Old 07-30-2008, 06:14 PM
colors? what are u talking about
Old 07-30-2008, 07:34 PM
right what wires am i pose to tap into for the line out converter in the truck?
Old 07-30-2008, 07:41 PM
the wires going to the speakers..... there might be some black fabric **** around them
Old 07-30-2008, 09:52 PM
Oh and it doesn't matter what wires I tap into? You talkin bout those wires that go in the speakers with the magnet facing down in the truck? What I put the right side of the converter to the right side of the speaker and the left to the left?
Old 07-30-2008, 10:29 PM
makes sense just strip a little of the wire and solder, or wrap around the line out converter wires to it, and tape it up
Old 07-31-2008, 04:15 AM
EmperorJJ1's Avatar
holy crappers... Tap the rear speakers for signal as shown in post 2. If you need wire colors there in the stickied in this section somwhere. If i remember chevies the negative rear colors are light blue and yellow. pos is dark blue and brown
Remote needs to be tapped on the inside fuse box on the passenger side. Ur going to want to use either the wiper fuse or sunroof fuse
Old 07-31-2008, 06:03 PM
Oh ok. Im about to do this now. I will post the result. Thanks
Worked like a charm. Thanks guys
Last edited by 07touringcoupe; 07-31-2008 at 06:03 PM. Reason: Automerged Doublepost
Old 08-15-2008, 03:31 PM
schamsy's Avatar
bump 4 me tonight...
Old 08-16-2008, 09:27 PM
FLYLIKEANINJA's Avatar
wow....so i did way more work to get my L.O.C. installled...i tend to do things the hard way though.
1. I removed the factory sub box
2. I took the factory sub out of the box disconneted the wires on each voice coil
3. then i attached the L.O.C. to the back of the the box and ran the leads inside the box through the little hole in the back of the box
4. I conected the left side and right side of the converter inputs to the two sets of speaker wires running in the sub box .
5. reinstalled the sub (not hooked up) and cover and then plugged my RCA jacks into the converter attached to the back of the box
6. bolted the box back in and ran the RCA behind the carpet and plug it into the amp.....and you never see a signal wire that wasnt already there
Old 08-17-2008, 03:37 AM
EmperorJJ1's Avatar
Lol all you had to do is buy 2/4 T taps tap the wires outside of the sub box unplug from the box itself and stuff behind the carpet. Not only is it faster but also you visually loose the wires going into the sub box.
Old 09-06-2008, 08:34 PM
hiltu's Avatar
im using a LOC on my pioneer amp, tried both using the rear speakers and sub and ain't getting crap. No sound, nothing, i even tapped in a bass processor which i figured would up the voltage of the signal and you guessed it nothing. What am i doing wrong? i have power to the amp
Old 09-06-2008, 11:19 PM
EmperorJJ1's Avatar
bass processor? where?
Test the VAC of the rcas to determine if your loc is actually giving output.
Old 09-07-2008, 08:35 PM
hiltu's Avatar
the bass processor is between the loc and amp
Got it!. the pioneer came with a harness that takes speaker inputs and turns them into rca's (not a LOC) and that got sound to the subs, but there was a lot of interference. I put the LOC back in and got a half a$$ quiet noise outta the subs. I grounded one of the rear speaker inputs to each and the signal was lost, did it to the other and nothing happened. I went as far as grounding the contacts on the LOC box for confirmation and sure enough, half of the LOC isn't working. Imma run down to the audio shop in a couple of days and buy a LOC from them.
Old 09-08-2008, 06:05 PM
creedin's Avatar
so i bought an amp for my subs, but my headunit sub out is week, i have after market speakers/amp, i want my subs, where should i tap into i also have after market wiring to those speakers) where should i tap into, like what speaker, only one speaker? how does it get all the signal? its headunit>rca>amp>speakers
where do i tap into? the rca or the speaker wire from the amp?
please help i want some bass? what type of loc is right for me?
Quick Reply: Line out converter???
