Line out converter???
Old 09-08-2008, 08:27 PM
EmperorJJ1's Avatar
how is ur sub out weak?
Old 09-08-2008, 08:30 PM
creedin's Avatar
a guy on crutchfield said his sub out was week and he had to buy a line out
my headunit gave no sound to my subs, adequate power and hookups, next thing is check the cabling which i will order 2morrow, but i hooked it up today after i got my amp back from kicker and nothing, green light on, but no sound
Old 09-08-2008, 08:34 PM
EmperorJJ1's Avatar
thats not a weak sub out. if theres no sound, theres no sound
are you sure everythings hooked up? if so spend buy a multi meter and test the VAC of the rcas at the amp side and see if they read anything
Old 09-08-2008, 08:40 PM
creedin's Avatar
vac? voltage ac? i have a multimeter, how would i test the vac on the amp side (unplug from amp and connect or?)
Old 09-09-2008, 01:53 AM
EmperorJJ1's Avatar
ya voltage ac
just unplug the RCA's and put one probe on the metal jacket and the other on the prong. try it with lower volume and you should read a low number but not 0 then crank it and you should read somewhere around 1 but it wont be exact
Old 09-09-2008, 06:56 AM
creedin's Avatar
okay i will do
Old 09-09-2008, 12:29 PM
EmperorJJ1's Avatar
k let me know how it goes and i can troubleshoot more until u get er workin
Old 09-09-2008, 12:52 PM
creedin's Avatar
well ya i mean i want them working so as much help as possible is wanted...
one question i know the 2 lines, one solid and one cut up is dc, which is ac on the multimeter...?
thanks, ill try this later
what if there is no volatage? first replace the wiring right?
Old 09-09-2008, 10:42 PM
EmperorJJ1's Avatar
not sure... all the ones ive used are labeled (for us dumbasses) if theres no VAC on your rcas then either the line output or the RCAs are bad... do the same test at the loc itself (one prong inside one on the jacket) to determine if its the rcas or LOC.
Old 09-10-2008, 01:49 PM
creedin's Avatar
i dont have a loc... just the headunit with 6 pre amp outputs, ill have to test the cable in the upcoming weeks when i tear apart the dash again...
Old 09-10-2008, 05:36 PM
  #36
EmperorJJ1's Avatar
If you have a HU with rca outs then its probably the RCA wire. any chance its a pioneer?
Old 09-11-2008, 07:39 PM
  #37
creedin's Avatar
no its a sony
Old 09-11-2008, 11:31 PM
  #38
EmperorJJ1's Avatar
ok nvm (theres an issue with pioneers that could have been it)
Old 09-14-2008, 03:46 AM
  #39
creedin's Avatar
i got the cables, but i cant do the install till next weekend, i have to swap out the harness for the head unit, get the new kit installed, install the battery, install the subs/amp, carpet the amp board, mount, ground the amp and clean my car... itll be a nice project lol
Old 09-19-2008, 11:39 PM
  #40
creedin's Avatar
the cables that were hooked up tested out okay... idk what it could have been, the headunit is sending signal to the sub from the sub out (i tested with the multimeter, and the signal fluctuates from about .5-.6 and so on, so its signal)
any ideas?
bad amp rca in?
Old 09-20-2008, 12:48 AM
  #41
EmperorJJ1's Avatar
tes the vac of the speaker output and see if u read anything
Old 09-20-2008, 12:52 AM
  #42
Spun's Avatar
Did you test before and after the RCA's (at the head unit and then at the end of the cables)
I think Emp said to do this once but anyway get a 3.5mm to RCA cable and plug your MP3 player into the RCA's on the amp, if the problem is still there then its the amp if not then its before the amp either cables or HU itself
Old 09-20-2008, 01:12 AM
  #43
creedin's Avatar
when its playing go positive to negative on the speaker terminals on the box?
will do later today
Old 09-20-2008, 01:43 AM
  #44
EmperorJJ1's Avatar
on the amp itself then on the speaker wires/terminals on the box. I assumed u already checked the RCA at the amp just as u did at the HU since it was the first thing i recommended but if not do skip my post and do spuns advice b4 testing speaker output
Old 09-20-2008, 04:30 AM
  #45
Spun's Avatar
Sorry i only read the last couple posts before I replied.
Old 09-20-2008, 12:06 PM
  #46
EmperorJJ1's Avatar
lol dont worry bout it spun
Old 09-20-2008, 11:34 PM
  #47
creedin's Avatar
okay well i took spuns advice and bought a mp3 adapter
first of all i ran the new cords after i tested the output from the headunit, which was varying, which is signal, so i ran it, and i hook it up... nothing...
the rca reds .019 and stays there
i hook up the mp3 adapter thinking, its the amp, and boom i get bass, and loud bass cuz i had my ipod all the way up...
i reconnect the rca from head unit, nothing
what am i missing?
Old 09-20-2008, 11:54 PM
  #48
Spun's Avatar
Give me the exact model of your Sony HU.
Good news is your amp is fine, could be that the HU is pouched but I think this might be a setting problem so once I have the model # I will know a bit more
Old 09-21-2008, 12:15 AM
  #49
creedin's Avatar
sony xavw1, double din touch screen
Old 09-21-2008, 01:17 AM
  #50
EmperorJJ1's Avatar
rcas shouldnt be reading .0___ more like .6
Your testing voltage AC and most hus are rated for 2v+ PEAK so you should get at the bare miniumum .5 with it cranked. You really just need to try it with low power and get .1 or .2 then crank it and get triple or whatever.
Did you test the mp3 unit at the amp or at the HU side of the rcas
Quick Reply: Line out converter???
