looking for a mono block amp!
I have to kicker cvx 1500watt dual voice coils running 2ohm per voice coil subs in a ported box, what would be the best mono block amp that would push them to there limit. I dont wanna pop them but I wanna run at least a 2ohm base cuz they are stable at two ohm, but will they run 1ohm since they are dvc? Im no pro when it comes to amps and subs
I found this amp, its a budget amp but a while back custom enclosers recommended that amp for what I had, but since they are 1500w max each can I safely run a 3000w total to both of them on one channel or just 1500w total on one channel to both
Amazon.com: MBQUART ONX1.1600D Onyx D-Class Mono Amplifier: Car Electronics
theres a good amp that should make those things bump real good and is 1ohm stable
