matching gauges
matching gauges
I wanted to put in a 3 pod pillar and start monitoring my iat2 temp and fuel pressure. is there a place i can get gauges that match the factory ones?
Rattlesnake Race Shop
Just get some new Auto Meter gauges... replace the factory boost gauge with a mechanical one. Don't get a fuel pressure gauge. You don't need it. Not in the cabin, at least. If you want to get useful gauges, think Wideband, EGT, Oil Pressure. If something goes screwy with the fuel pressure... you'll see it in the wideband.
Here are mine. Auto Meter ES Series.
From top to bottom: Oil Pressure, EGT, Boost -30in/hg to 30psi
In front of the cluster is the wideband and Interceptor.
...and they can't. Contractual agreement between them and GM, iirc.
z28addiction
09-28-2015 12:03 AM
