my little setup
my little setup
hey people.new to the board so i thought id say hi.
im into the car audio in the most part.but a car fan never the less.
a few pic's of the junk in my trunk.
second amp is used only in spl comp.
amps are up for sale if anyone's interested.
looks like ass.this is just spl
my gear comes out in the fall till next spring.
not built for looks.
im guessing thats what your getting at.?
each amp benches at 2800Wrms @2ohm
running with a 16volt lowed.
im pushing 147.9db and hoping to hit the 150db by summers end.
so fare so good i haven lost a comp yet this year.
the over all setup is just under 700lb's
200lb's of that is just in copper wiring.
its a real gas killer.
yes.4/G to the subs.
im upgrading the amps this winter to soundigital
im getting 2 SD8000
ill have 30.000Wrms @0.5ohm for next year.
ill be running either 4 12's or 2 15's of the TFone subs
im getting 2 SD8000
for SPL its the safest place for a fuse.and the more fuses in the tree the weaker the volts become.
ill dig up or take a pic of the volt readout.is that what you mean.?
wow holy wires............ luks like sumone has been stealing VDUB wiring harnesses lol
im using 2 marine high/discharge batteries.with to 5 farad voltage sensitive capacitors tuned at 16volt.
most capacitors are voltage sensitive if you take the top off you'll find a small dial to tweak the volts.
you would be surprised how much better your amps will run with a higher volt.but be sure the amps your using is capable of a lowed higher then 14.4V
the ZX models im using now will do a 17volt lowed.
im having a second alternator installed over the winter that runs 16volt with a voltage regulator built into it.made by powermaster
this is why my fuses are at the end of the lines.i dont care about alts batteries or cables.just the amps.
how much did you pay for your kinetik 16v batteries.
im looking to buy a set of the powermaster D1000's in 16V
i can get a price break if i order both bats and a xsvolt alt at the same time.but if its a large price difference i might go with the kinetik bats.
what are your volt readouts at the amps when under a heavy lowed.holding stable around the 16V range.
but as for the car....lut the bitch burn.ill have a great video to post.
O and i love the job you did on your door pods.they look mint.
well i paid dealer price on the kinetiks so by far cheaper then the powermasters
I really haven't pushed it hard just yet. Ive only had the alt running the past few days and wired up just today. I really don't think ill see much of a voltage drop but 16.6 is a good estimate of the by far worst i would see. the kinetiks sit right at 17v fully charged and even running at 1krms i wouldnt have it all the way up all the time
Oh btw you might be able to get a price break if you mention your a competitor and talk to gus at ohio gen
thanks
thanks
but they don't actually fire right into each other.they are under/over.one is firing over top of the other.im working one a new set of boxes now.that are built a bit differently and a bit smaller.
i should have mentioned that that was a pic from the start of the summer.ill post the new one once its in and tuned.
thanks
thanks
my friend got a 300amp alt from them this spring.it showed up a dud.they sent him a second alt free of charge and told him to keep the first one.
thats the type of people i like working with.
I don't care if it's for SPL or not.... Put some carpet on that **** atleast make it look decent.... it looks like crap but thats me... Emperor's system looks nice and put together!
RIGHT ON DUDE! i love fellow music peeps
anybody every look into a carPC?
www.mp3car.com
my goal is to have absolute control over my entire range
www.mp3car.com
