Need Help
Need Help
So i have every wire connected right into the harness and everything the headunit powers up and functions and except no sound coming out of the speakers, i even rewired them and tried again and still no sound at all, would anyone know what this is?
Yeah... I had the same issue as you, did everything right and no sound either, turned out to be some stupid pinkish colour wire I had to tap into
http://www.***************/forums/au...-no-sound.html
check that link, its some bluish coloured wire that I tapped to the pink one and everything was perfect after that.
ugh stupid .net wont let me link www.y o u r c o b a l t links...
wwell anywhoo it was a blue wire OUT on the deck that I tapped to a PINK wire on the factory harness to activate the factory amp.. worked for me and countless others who had the same issue as you try it out, tell me if it works.
