Need HELP! Cruise Control
As most of you know, you turn on the cruise control and it shows "Cruise Engaged" for a few seconds on the dash. Recently it will say that for a split second and then disappear. And the cruise doesn't even activate. My cousin said it could be the brake switch. ..? Any idea what the issue could be, and how to fix it? Thanks for reading.
Had the same problem just make sure atleast one of the light is good on ur 3rd brake light and should work prefect if u do and if u dont that y it wouldnt work and they cant b led cuz it will b same problem
This.
The other advice about the brake switch could be right but don't you think that if your brake switch was shorted or not working properly you would have other signs? Like brake likes being on all the time or maybe the brake light lit up on the counsel?
Cruise control can be tricky but gm does wire it through the 3rd brake light so if that's out it won't work.
mine was doing the same thing. I gave up on it. then I did a clutch swap and now it works. idk what happened. maybe having the battery unplugged for over 12 hours? maybe magical fairies? idk.
I had this problem on my 06 and what fixed it was putting my foot underneath the clutch pedal and pulling up. Seriously, it worked flawlessly after. Clutch pedal was just ever so slightly tripping the signal to disable cruise control I guess. Worth a shot ha.
