need help installing subs and amp
ok here i go i'm keeping the stock HU and i'm adding subs and amp all i need to know is 2 things where should i hook up the remote wire? and i bought the converter hi low thingy but i can't tell which is the + and - of the rear speakers anyone help me out??? i have a ss sc thanks..
Run it from the Red/Power wire of the cd player...This way when you turn the unit on the amp will turn on. Im not sure if it red but do a search for a thread called pin out
Ok i did what you are trying to do and then i changed my sub and amp and after the switch it didnt work (fucken pissed) so im just getting a new deck. I know its not any help to you but its not worth all that crap/ taping into speakers and suff IMO. I know it will work good if you can get it all hooked up right and **** but its just not as easy as getting a new deck.
Originally Posted by mikess06
i got everything else hooked up i just needed to figure whats the + and - on the rear speakers both i believe have black lines on them
The darker wire will be the ground....
Originally Posted by my self
I just used my DMM and tested the wires in the back of my car.
Back L
black (+)
yellow (-)
Back R
Dark Blue (-)
Light Blue (+)
Back L
black (+)
yellow (-)
Back R
Dark Blue (-)
Light Blue (+)
This is from an 06 ls though
Delta coupe
09-30-2015 08:11 AM
