Need help with passenger fuse box
Ok, I know there are million threads about this but I cant seem to find any straight answers. Im having problems with my AEM a/f gauge getting power. Im currently using and Add-a-fuse wire and its going into my wiper fuse position in the passenger fuse box. Well a long time ago i 1st tried those piece of **** fuse taps and it ended up pushing the contacts deeper inside so this particular connection is "Loose" you could say. If i have manual windows and i dont have a sunroof and there's no fuse in the sunroof hole is it still usable as a switched power source. If not what else is a switched power source in the passenger fuse box. Which fuse positions are switched and stay on until the door is opened? Please respond with some decent answers and not be smartasses about it. Thank you.
I wasnt sure where to post this so I posted here and in the 2.2 L61 section.
I guess my car is one of kind or something. Its just a standard base model 2006 with manual everything. I have no power going to the sunroof fuse position.
get a better add a circuit, make sure u have 2 fuses in the add a circuit, and u can put it in the sunroof slot or wipers slot. MAke sure you have power by checking with a meter first though and save yourself some headaches.
