Need help picking out new subs
Old 02-23-2012, 01:21 PM
  #76
toysareforboys's Avatar
Originally Posted by hoop
Wait what? Lol...I'm going to connect the stock pioneer sub wires to my...amp?
Your "new" Punch 800 has speaker level inputs, how else were you planning to get the audio into your amp? I thought you already had an amp and 12's connected, you're just upgrading?! Isn't that how you've got it connected right now??
-Jamie M.
Old 02-23-2012, 02:14 PM
  #77
nizzle's Avatar
If it were me I'd use a Low level to RCA line converter. Using the low level inputs on amps sucks ass IMO. In addition, using low level inputs leaves you no way to control your sub level except by adjusting bass levels which is crap . You can get a RCA line converter that has a level control to give you the ability to control the actual sound signal level going to your sub amp for better control. Also, the line converter can also give you a true remote wire vs having to connect an accessory wire to the remote input on the amp. Thats what I'd do if it were me and I was keeping the stock H/U.
Old 02-23-2012, 04:14 PM
  #78
hoop's Avatar
I'm still confused. Right now I've got an aftermarket head unit connected to my amp thru rcas and a remote wire spliced into the stock remote wire. I'm just looking to get rid of the stock pioneer 10" so it sounds better and I've got more power to work with.
Old 02-23-2012, 04:17 PM
  #79
Ohhhh! LOL! Yeah, you can pull it out no problem. Four nuts to take off and there is a little clip you can just disconnect the sub wiring harness, follow the wires coming out of the sub box, the connector is usually tucked behind the side carpet, no cutting wires no nothing
Piece of cake!!
-Jamie M.
Old 02-24-2012, 01:28 AM
  #80
hoop's Avatar
Alrighty then.
Welp, I got my car back from the shop and I've got two fancy new cvr12's in a ported box
But they're bring powered by my RF p3001 not the 800a. Apparently it "powers on but there is no audio output. So it's basically a paperweight."
Oh, well. The guy quoted me a "hifonics crunch gtr" amp for $220.
Old 02-24-2012, 01:34 AM
  #81
EmperorJJ1's Avatar
what happened to the 800a2? i might be able to get that amp fixed for u but for 2 cvrs not quite the power they need. u still have d4 or d2?
hifonics is ok but not really rf quality. amps id be ok with subs id steer clear from
Old 02-24-2012, 01:49 AM
  #82
hoop's Avatar
Well the 800a2 was sitting in my buddy's basement for a while. The shop bench tested it and said it powers on but there is no audio output
But yeah the cvr's are 4ohm now.
Old 02-24-2012, 02:12 AM
  #83
EmperorJJ1's Avatar
ok so u have the p3001 on there now playign right?
let me ask my old boss if hed be able to get that 800a2 working for u and how much it would be
Old 02-24-2012, 04:52 AM
  #84
hoop's Avatar
Yeah the p3001 is working now.
Old 02-24-2012, 08:22 PM
  #85
EmperorJJ1's Avatar
whats ur e-mail bro or do u have a facebook?
Old 02-24-2012, 10:36 PM
  #86
hoop's Avatar
Pm'd
Old 02-25-2012, 01:52 AM
  #87
rekameohs_nire's Avatar
hey im kinda new to the sub world but my friend is selling some stuff and i want to know if its any good. he has 2 12in JL audio w3's and a lanzar max pro 2 channel 2000 watt amp. and i have a ported box for 2 12s that i currently have 2 sony xplod subs that i had like 4 years ago. he wants 300 for the subs and amp. is that a good deal and can i put them in the box that i have?? thanks
Old 02-25-2012, 12:13 PM
  #88
anyone?
Old 02-25-2012, 02:24 PM
  #89
W3's are pretty descent, nice clean tight bass. You should find out if they are a dual 2 ohm model or the dual 4 ohm model. If they are the dual 2 ohm model they won't work very well on the amp you mentioned.
User manual for that amp is here: Lanzar - MAXP2760 - 2000 Watts 2 Channel High Power Mosfet Amplifier
Specs look OK. Says it should be about to do about 750RMS x 1 @ 4 ohms bridged. That power level is good to use with the W3's.
Cheapest I could find mint 12w3's around me was $125 so that amp for $50 is a good deal.
Can you take a pic of the box you have? Measure the outside dimensions and the length and diameter of the port?
Ported boxes are more sensitive to swapping out the sub, they are designed specifically for the sub they intended to be put in it.
-Jamie M.
Old 02-25-2012, 09:21 PM
  #90
EmperorJJ1's Avatar
Pm'd
i sent ur info to him hope it works out
Old 02-25-2012, 11:43 PM
  #91
-Jamie M.
box is 32in wide 16 tall and 17 deep and the port is about 6 in across and about 12 inch long inside..
Old 02-28-2012, 12:18 AM
  #92
Supercharged06SS
12-11-2022 04:47 PM
dennis69
10-20-2015 07:39 AM
HEATON
10-16-2015 07:21 PM
riceburner
10-02-2015 05:47 PM
c_m_shooter
09-27-2015 04:40 PM
Quick Reply: Need help picking out new subs
