New Headunit - All parts? help an electrical noob
Just double checking if these would all work and if i would need anyhthing else? I know i wont have the door chimes but I'm fine with that. New to audio but i want to learn and attempt to do it myself.
Looking to put in this: w ww.hdradio.com/buyers-guide/car-stereo/pioneer-deh-4400hd and from looking through this: https://www.cobaltss.net/forums/elec...aq-read-96094/
All i need is:
Harness - w ww.ebay.ca/itm/220690784968?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649#ht_2064wt_1139
Antenna adapter - w ww.ebay.ca/itm/390437273272?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649#ht_650wt_1271
harness - w ww.ebay.ca/itm/370456263766?ssPageName=STRK:MEWAX:IT&_trksid=p398 4.m1423.l2649#ht_1967wt_1139
All i need is:
Yep so get the 70-2104 and the 40-CR10 antenna adapter, just like he said. You'll be golden.
Also make sure you get an add a circuit to get your 12v+ switched source, this wire will come from your fuse box, and attach to the red wire on the aftermarket headunit.
