New sub
no offense dude but people think these subs are the best out there...when in all reality they aren't...I can't see spending that much on a 10 when you can get a better quality subs for less. I'm not sure if you know alot about the specs of a sub and what they mean but these subs only have an efficiency of 83.7dB's at 1W/1m. Yeah they have that clean looking cone that's well known but they aren't worth the money companies charge for them. Take for example the sub's I'm going to be picking up soon which is the Audiobahn ALUM10N. check out these specs for under $100 a sub and ebay it's cheaper.
Features
PHAT 1.75” EPDM Rubber Surround
Spun Aluminum Cone
Dual 6 Ohm Voice Coil
Multi-connect Lug Lock Terminals
Magnet Weight: 120 oz.
Mounting Depth: 5"
Hole Cutout: 9 3/4"
Outer Diameter: 10 7/8"
Subwoofer SpecificationsSize: 10 inch
Rec. Sealed Box Dims: 0.50 - 1.25 cu. ft.
Rec. Ported Box Dims: 0.60 - 2.35 cu. ft.
Free Air Usage: not recommended
Sensitivity: 95.6 dB
Frequency Response: 20-500 Hz
Recommended RMS Power: 800W
Peak Power Handling: 1600W
Impedance: dual 6 ohms subwoofer wiring options
This reply is in no way to flame you or be a dick, i just hate to see another get sucked into the whole "JL W6/7" sub craze. There's comparible out there for less. If JL is only what you want then that's cool I just thought i'd throw in my 2 cents
Features
Spun Aluminum Cone
Mounting Depth: 5"
Hole Cutout: 9 3/4"
As far as the rating being 400 watts RMS, you can definitely atleast push 600 into that sub CLEANLY. What is the subs peak power? If it is over 600, then you should be fine.
Why?
Music is not played in Sine waves. We use sine waves to tune our amps so that we know exactly where we reach the amps particular limits before pushing the amp into a zone known as clipping, a very bad thing to do. Basically, clipping is forcing an amp to amplifier a squared wave, which increases the amps output dramatically, and also send near 2X the power to your driver in an ugly, cluttered mess of waves. These extra waves cause are the 'extra' tone we can hear when we push an amp into distortion during a sine wave, but is only heard as distortion during music.
So, music is played and referred to as dynamic. Dynamic meaning that the signal being playes is not a constant, but because the music varies in tones and recording, sometimes we will only hear 300 RMS out of a 600 watt RMS amp being played through a sub because of music recording levels, although safely, we can say a sub on a 600 RMS channel can see up to an average of 500 RMS at FULL TILT. The reason why you can put a 600 watt RMS into a 400 watt sub, is that tuned correctly, you can play the sub cleanly to probably atleast 500 watts RMS before pushing mechanical limits during heavy bass songs. I would suggest this ONLY if you understand a speakers limits, why they blow, and how to fine tune systems.
As for suggestions, especially around the $100 mark; A Phoenix Gold Xenon or Rsd line will blow that Audiobahn out of the water regarding SQ and clean output ANY day, and cost as much. Heck, an audio tech sent a 2,000 watt RMS sine wave into an Rsd sub for 20 minutes and the thing heated up but would not blow. People are handing the Rsd up to 1200 watts RMS and daily driving, all out of a sub that costs less than 130$ shipped.
~Levi
Why?
~Levi
Why?
~Levi
I've yet to go figure out why my amp is blowing fuses.
I know all about tuning the amp for the sub and why subs blow(Distortion aka clipping). I haven't done it recently because I don't have access to a mutimeter, but I usually tune the output voltage of the amp to be optimum to the sub. If I'm in a hurry I gain it to where it sounds clean(no more than 1/2 to 3/4 gain).
Checked to make sure no strands are touching a ground pount on the amp?
And that's about all I can think of, besides the amp just being bad.
Good luck,
~Levi
I just checked it all, there are no power line pinches, ground is fine, and there are no strands going between power and gound. and theres a smell of burnt PCB in the trunk. I do have a 4 year replacement plan with Circuit City on the amp. I may just have to call them up on it.
The power wire is liekly fine as the fuse under the hood for the amp wire(you had damn well beter have one) would blow if the power wire was crossed.
Other then that the fuse on the amp is usualy for the speaker wires. Disconnect them then insert the fuse. if it still blows then the amp is likely FUBR.
Jl underates there amps by a decent margin. This is why their CEA2006 ratings are usualy alot higher then their own ratings. The JL 500/1 for example is near a 750 watt rms amp, not a 500. Although the RIPS circuit should keep it near 500 watts at all loads, it really doesn't. Real world power will be closure to the 750 at 2 ohms so that is what you should run for a load.
i have owned and used the Jl 300/2 (2 of them) Jl 300/4 (only one I still have) and a Jl 1000/1. All where flawless and incredible perfomers. Even the ones I sold are still going strong. I sold the e/a series but never owned them. The 6450 is sadistic. You can run it as a 3 channel at 220 watts x2 for the fronts and near 450 watts rms for the sub. The 5/6 channels bridge for alot more power into the sub audio range. If i can fit it in my truck, I might use it over my 300/4
Yep, my friend just came over, I pulled the remote and put two brand new fuses in, hooked the remote back up...Now it starts to goto power but then jumps back to protection mode but doesn't blow the fuses. IT'll keep trying to goto power but keeps defaulting to protection. So can you confirm my fear that my amp has taken a dump on me?
#36
Yep I've decided she fried...how I have no Idea. I'm gonna go look around locally tomorrow and see what else there is...I may be able to borrow something from a friend so I don't go insane.
#39
#41
#42
Yep, I'm thinking about getting a stereo amp to push my rear infinitys too.
And yeah I got that design!
Would this one be too much?
http://cgi.ebay.com/New-MA-Audio-800...QQcmdZViewItem
#43
Anybody got any opinions on the Fosgate power series T5001BD. I just bought one to push a Fosgate Power series 12" T112D2. The power on this amp is incredable. Cant wait to install it, but dynamatting my whole trunk first. I have had good luck with fosgate in the past, just kinda wondering what other people thought of them?
#44
I have. And to me there like flushing $$$$ done the drain!!!!!!!!
Biggest flashy POS subs I have ever had.
They distort easy, blow even easier, look like crap, sound like crap if your going for sound Q not just stupid loud, and they are over rated for there power handling. What ever they are rated at, cut that to 30% and thats about what they can actualy take if you put a good amp to them.
To the thread starter that looks nice man.
Later
Later
#45
If you are going to shop online, then don't bother with Jl. its not worth throwing away the warrenty. Go with a different brand that is more supportive of online sales. JL is about the worst.
#47
you get what you pay for... you could also go for some kickers for about half the price that's why i ended up with 06 L7's and a kx1200.1 payed about 800 for it all even with a tuned ported box.. it was worth all the money i spent also.. don't get audiobahn there way more for looks than performance. they sound good for a mild setup but i would never get one. i would choose Rockford any day for a decent setup if i was on a budget..
#49
I was thinking about these subs b/c their specs look decent and the price is pretty good
http://cgi.ebay.com/2-BLAUPUNKT-VELO...QQcmdZViewItem
Details:
» 10" subwoofer with dual 2-ohm voice coils
» woven carbon fiber/fiberglass hybrid cone with rubber surround
» cast aluminum basket
» grille included
» frequency response: 20-200 Hz
» power range: 500-1,000 watts RMS
» peak power handling: 2,000 watts
» sensitivity: 87 dB
» top-mount depth: 5-3/4"
» sealed box volume: 0.4 - 0.8 cubic feet
» ported box volume: 0.6 - 1.4 cubic feet
» Recommended Q-Logic Box Type: 1, 2
» warranty: 1 year
![](http://img379.imageshack.us/img379/3746/subs1wa9.jpg)
-or these JBL's
Details:
» 10" subwoofer with dual 4-ohm voice coils
» Kevlar-impregnated paper cone with Hi-roll rubber surround
» Plus One cone design for more effective surface area
» power range: 50-400 RMS watts (200 watts per coil)
» 1200 watts peak power handling
» frequency response: 25-500 Hz
» sensitivity: 92 dB
» mounting depth: 6-13/16"
» sealed box volume: 0.75 cu. ft.
» ported box volume: 1.25 cu. ft.
» Recommended Q-Logic Box Type: 1, 3
» warranty: 1 year
![](http://img411.imageshack.us/img411/3992/subs2rg5.jpg)
What do you guys think about these?
Details:
» grille included
» warranty: 1 year
-or these JBL's
Details:
» warranty: 1 year
