No Dash Lights!
No Dash Lights!
OK so I put my retrofits in yestursay everything works fine except I left my angel eyes unhooked since I needed a soidering gun. Now everything works except my speedo, air control, window lights. I checked all the small fuses and all of them were good. I even swapped out the dimmer switch since I had another and no dice. Any help would great thanks.
parkin lamp fuse? I don't know why yer Hvac lights went out, i thought that was on another circuit... sounds like jus some bad shiiiit...
jus make sure yer wires are all tapped in right.. I don't know why you'd have to solder any wires for you Halos but... do watcha wanna do
but do like ole boy said an unplug em, check the wiring..
Bad wirin in my taillights blew my parking lamp fuse,dash cluster went out.
Bad wirin in my headlights did the same thing few months later
check your parkin lamp fuse(fuse box under hood), and your cluster fuse(passenger side kick plate I think they call it?..)
Cluster's a 10 amp (ithink) an prk Lmps a 20 amp
We pulled the lights out still didn't work. Put them back now they are good Idk. I'm just glad they work.
I have to soider I'm halos to some power source. What are you guys hooking them too?
I didn't like how pinkish mine looked so painted part of em so it looks like mean eyes I likes it tho...
But i tapped em into my parkin lights(brown wire) an the negative to a blk wire
z28addiction
09-28-2015 12:03 AM
