no reverse lights
Old 01-30-2016 | 04:25 PM
coltonjohnbutler's Avatar
no reverse lights
Hey everyone, I'm new here. I have a 2005 Cobalt ss supercharged 5 speed. My reverse lights don't work. I've tried everything I can thing of. Checked every fuse, all good. Replaced reverse sensor on transmission, didn't help. Checked the wiring under the seats, all good. And the bulbs are good and work but I have no power to the lights. The fuse slot has power, as well as the actual plug for the reverse light switch on the transmission. I am at a complete loss as to what could be the problem. So any help would be greatly appreciated. Thank you!
Old 01-30-2016 | 04:32 PM
ssyellowss's Avatar
I know you've replaced the switch but try this: unplug the reverse switch connector and short out the two wires at the connector to simulate the switch engaging. Use a piece of thin wire. Report back.
Old 01-30-2016 | 05:56 PM
I did that and they turned on. Now what? Lol
Old 01-30-2016 | 06:33 PM
ssyellowss's Avatar
Since the switch is new and still not working that means the transmission is not engaging the switch or the new switch isn't working either. You can take the switch out and press it by hand while connected. If that works then your transmission isn't engaging the switch when shifted to reverse. If it doesn't work you switch is bad, again.
Old 01-30-2016 | 06:36 PM
Yeah that's what I did, I took the switch out and pressed the switch manually and they worked. So does that mean that there is something broken in my transmission or does the linkage just maybe need to be adjusted?
Old 01-30-2016 | 07:05 PM
ssyellowss's Avatar
If you can shift into reverse without issue then the linkage is fine. I am not sure for a fix for this particular problem.
Old 01-30-2016 | 07:08 PM
Damn.. Okay thank you for your help. Much appreciated!
Old 01-31-2016 | 11:12 PM
EmperorJJ1's Avatar
that sucks. i guess you could wire them to a switch?
Old 01-31-2016 | 11:13 PM
Yeah I'm thinking about just wiring a switch in the shift boot.
Kohl Wall
02-17-2016 01:35 PM
Gamma_Beat
02-12-2016 06:28 PM
Staged07SS
02-10-2016 08:34 AM
ssyellowss
01-29-2016 07:03 PM
Olybaltss
01-29-2016 01:09 PM
Quick Reply: no reverse lights
