Optima battery?
Optima battery?
i was wondering if anyone on here has installed an optima battery on their cobalt. i just got my system installed and need to upgrade the battery...i checked out their website and they don't have one for the cobalt...but i know one they have out now will fit...so back to the point, for anyone who bought an optima what was the code/model number on the battery??? any help would be great!
I transferred my Red Top from my Monte Carlo into the Cobalt. I had it in the trunk of the MC for about 9 months. I don't have the series or model info on hand but it fits perfectly into the Cobalt's battery tray and the stock cables latched on to the posts nicely.
Edit: After browsing Optima's website, Their 34 series sounds exactly like the battery I have. Hasn't failed me yet. I don't have the details off my batt but this Jegs PN is probably the same thing I have. 753-9002-002
Had yellowtop in my 99 cougar and loved it. Might have to put one in the cobalt as well!
I could notice big changes in the cougar after installing it.
Yep, that's what I got from it.
Blue of course for marine.
The alternator in 99coug was really bad. and I tried putting in so much stuff, extra fog lights (looked like an airplane from the front) lol, whole bunch of stereo sht.
Crusing down highway telling friend "I can turn up the stereo all the way, and these speakers should keep good quality" so I start turning it up louder and louder, then my car shut off cause the alternator blew LOL
The only issue is the yellow top may be a *tad* taller than the stock ACDelco and the back of the spare tire cover will stick up a little, other than that it will be fine.
vehcile starts alot easier (especially when cold), accessories never dim with bass, you can leave the radio on with vehicle off for hours on end and it will fire right up, jumps other vehicles easier. plus, with dual terminals it is easier to ass accessories.
Originally Posted by HackAbuse
Not to burst your bubble, but aftermarket batteries like that normally half only half the capacity as the stock battery, which means they shouldnt run as long as a stock battery would
Optima batteries are in a class all of their own. Stock batteries suck! I mean come on, one guy left a FRIDGE plugged in all night! The stock wouldn't of lasted an hour or two max!!!
Originally Posted by marerick007
Where did you get that info from?!?!?! Do some research and post proof to back up claims like that before you come out and say some crap which you apparently have no idea about.
I can see them allowing the vehicle to start better, but where your accessories are dimming and compnents are slowing or turning down thats your alternator. Your battery is only for starting and then once the vehicle has turned off. Everything else is run off the alternator. That means your stuff dulling out from bass or a system you need to upgrade your alternator.
The only advantage to the Optima is starting and if you leave things plugged in a LONG time. The AcDelco batteries are great batteries and if you run them completly out you have a 6 year warranty on them!
Stock alternator for the cobalts are 115 and i believe the SS/SC's have a 125 amp.
Dude, did you NOT READ what I said! ACCORDING TO CHEVROLET.COM, THE STOCK ALTERNATOR IS RATED AT 105 AMPS.
See for yourself, all three are the same rating!
http://www.chevrolet.com/cobalt/specifications/
Then click on Engine tab....
I was just getting at the fact that the Stock battery is labelled to be 55Ah, when a Yellow Top is labelled for about 30Ah. The Optima would be able to output more amperage, but in an endurance test, the stock battery would last longer since it has a much larger capacity. I know quite a bit about batteries, I built battlebots before I got into cars...
Go look up your RPO codes. My balt has a 115 amp alternator. so calm down skippy. (I have an 06, we looked them up and the alternator was 115)
