pics...door panel removed????
any pics with door panel removed????
Well, I deadened the car last weekend. This week it is the doors.
With the door panel off, Is there enough room/openings to get my hands to the outer door skin so I can lay some mat? Its an LS no power windows or locks.
Does anybody have a pic of their door with the door panel removed? thanks
I used Fatmat. My other car is done with dynamat. Being as this is my daily driver and 'budget' system, Fatmat was cheaper. So far Pros.....stuff is sticky...stickier with very small amount of heat. It is pressure sensitive...it is not made to be applied with heat. Cons....stuff is sticky! whatever it touches will be stuck to it.
So far I did the floor front to rear, quarter inner and outer skins on each side of the rear seat and the walls in the trunk. My sub will fire into the cabin with the pass rear seat down so I wont have as much of an issue with the trunk vibrating as others. I my have the sub fire through the rear deck but I dont know if I want to remove the rear glass to install it.
chris88z24
09-08-2015 01:55 PM
Getaway_Driver
09-08-2015 09:41 AM
