Pioneer + Aftermarket Setup
Old 01-18-2011, 10:22 PM
EmperorJJ1's Avatar
ya amp is sorta shitty. deck is nice, speakers arent bad
https://www.cobaltss.net/forums/elec...aq-read-96094/
Old 01-19-2011, 11:47 AM
padlock's Avatar
yea i plan on running that amp temporarily until i get a bigger one because i know that amp isnt even close to being able to push the subs.. its like a bare minimum for now
does best buy carry the metra dash kit and harness i would need??
Old 01-19-2011, 11:52 AM
padlock's Avatar
so after reading that thread u posted i will need the following? seeing as im a 07 with the Pioneer system
Single DIN kit number
Metra = 99-3302
07+ Cobalt's need the Chrysler antenna adapter
Metra = 40-CR10
Scoshe = CRAB
7.) Is there another solution other then the pricy gm lan harnesses for 07+ vehicles?
Yes you can buy the regular harness that will plug in but you will loose your door chimes.
Metra = 70-2202
Old 01-19-2011, 12:47 PM
EmperorJJ1's Avatar
they should yes... look for the 710-2104 vs the 2202
Old 01-19-2011, 01:55 PM
padlock's Avatar
alright good to know!
its wierd how we need a chrysler antenna adapter....... hmm
Old 01-19-2011, 05:54 PM
Oh how it feels to be a
balt_ls's Avatar
Metra = 70-2202
I think the only reason you need the expensive one is if you have onstar. I have the pioneer system and i bought the cheap one and didn't lose my door chimes or anything.
Old 01-19-2011, 07:09 PM
padlock's Avatar
ok im going to pick up the system tonight! along with the din kit, the 710 2104 harness, and the 40 cr10 antenna adapter
Old 01-19-2011, 10:48 PM
EmperorJJ1's Avatar
yup all new gms, chryslers and fords use said antenna adapters
Old 01-20-2011, 10:28 AM
padlock's Avatar
best buy was out of stock on the harness i needed (imagine that) so ill be picking that up soon otherwise i tucked all my rca's and stuff last night and im driving without a radio at the moment just waiting to get my HU in..
now since i had a pioneer system, what do i connect to what to make the speakers work? because wont i need like a "remote wire" kinda deal going to the stock amp to make them work??
Old 01-20-2011, 02:55 PM
padlock's Avatar
alright kinda figured this would happen.. got the harness hooked up correctly but now my airbag light is on along with the car/lock light (whatever that is)... and the pioneer speakers dont work.. only my sub/amp is working..
what do i need to do??
Old 01-20-2011, 07:22 PM
  #36
padlock's Avatar
bumpity bump!! NEED HELP ASAP
Old 01-20-2011, 09:38 PM
  #37
padlock's Avatar
thinkin i had the wrong harness put on..... fk me....... now which harness do i need for an 07 pioneer no onstar?
Old 01-20-2011, 10:53 PM
  #38
EmperorJJ1's Avatar
what harness did u get? and how did u hook it up (blue and red wires) did u at any point start the car or turn it on with the pass airbag sensor unplugged?
Old 01-21-2011, 10:24 AM
  #39
padlock's Avatar
see thats the thing im not 100% sure which harness i got cuz i got it from a local audio shop that they "said" would work.. they then wired it onto my HU right away and i went home thinking that all was well.. i guess not
the airbag sensor was always plugged in
also when the tuner or cd player was on the speedo/gas gauge/tach would all drop down to zero like the car was off.. wtf
Old 01-21-2011, 10:26 AM
  #40
Turbalt2010's Avatar
is the deck/harness compatable with the car? i know there was something about a deck/harness i bought it was fully compatable with my vehicle and lil **** when i put my window down the music would stop for a few seconds but the bass would keep going. maybe your **** is either hooked up wrong or the deck/adapter thing is not compatible with your car.
just my .02. i could be wrong thou. just trying to help.
Old 01-21-2011, 10:27 AM
  #41
padlock's Avatar
i gotta go to college in 2days so i need my car back together asap.. ugh.. just another reason to hate my balt
Old 01-21-2011, 12:59 PM
  #42
EmperorJJ1's Avatar
that happened to me when i used the saturn harness before...
Old 01-21-2011, 02:24 PM
  #43
padlock's Avatar
problem solved... i noticed the pins didnt line up at all so i re-pinned the harness to what the balts harness should be after looking through many harness pictures and everything is working :fingerscrossed:
Old 01-21-2011, 10:52 PM
  #44
EmperorJJ1's Avatar
sounds good then. you probably had the saturn harness and put some sort of power or speaker input into the gm lan wire
01-12-2016 12:01 AM
patooyee
10-15-2015 05:11 PM
ThoR294
10-04-2015 08:44 PM
nathan112i
09-30-2015 07:12 PM
09-27-2015 08:53 PM
Quick Reply: Pioneer + Aftermarket Setup
