Pioneer + Aftermarket Setup
ya amp is sorta shitty. deck is nice, speakers arent bad
https://www.cobaltss.net/forums/elec...aq-read-96094/
yea i plan on running that amp temporarily until i get a bigger one because i know that amp isnt even close to being able to push the subs.. its like a bare minimum for now
does best buy carry the metra dash kit and harness i would need??
so after reading that thread u posted i will need the following? seeing as im a 07 with the Pioneer system
Single DIN kit number
Metra = 99-3302
07+ Cobalt's need the Chrysler antenna adapter
Metra = 40-CR10
Scoshe = CRAB
7.) Is there another solution other then the pricy gm lan harnesses for 07+ vehicles?
Yes you can buy the regular harness that will plug in but you will loose your door chimes.
Metra = 70-2202
Metra = 99-3302
Metra = 40-CR10
Scoshe = CRAB
Metra = 70-2202
Oh how it feels to be a
I think the only reason you need the expensive one is if you have onstar. I have the pioneer system and i bought the cheap one and didn't lose my door chimes or anything.
best buy was out of stock on the harness i needed (imagine that) so ill be picking that up soon otherwise i tucked all my rca's and stuff last night and im driving without a radio at the moment just waiting to get my HU in..
now since i had a pioneer system, what do i connect to what to make the speakers work? because wont i need like a "remote wire" kinda deal going to the stock amp to make them work??
alright kinda figured this would happen.. got the harness hooked up correctly but now my airbag light is on along with the car/lock light (whatever that is)... and the pioneer speakers dont work.. only my sub/amp is working..
what do i need to do??
#39
see thats the thing im not 100% sure which harness i got cuz i got it from a local audio shop that they "said" would work.. they then wired it onto my HU right away and i went home thinking that all was well.. i guess not
the airbag sensor was always plugged in
also when the tuner or cd player was on the speedo/gas gauge/tach would all drop down to zero like the car was off.. wtf
#40
is the deck/harness compatable with the car? i know there was something about a deck/harness i bought it was fully compatable with my vehicle and lil **** when i put my window down the music would stop for a few seconds but the bass would keep going. maybe your **** is either hooked up wrong or the deck/adapter thing is not compatible with your car.
just my .02. i could be wrong thou. just trying to help.
#42
#43
problem solved... i noticed the pins didnt line up at all so i re-pinned the harness to what the balts harness should be after looking through many harness pictures and everything is working :fingerscrossed:
ThoR294
10-04-2015 08:44 PM
